Topic: Enclosure for MKR Env Shield that is transparent to UV (Read 303 times) previous topic - next topic
garywil
I bought a watertight enclosure with a transparent plexiglass lid to put the MKR Env Shield in so I could measure Illuminance and UVA/UVB.  I did some measurements and although the Illuminance doesn't change with or without the lid, UVA is reduced about 35% and UVB about 60%.  Has anyone found a watertight enclosure with a lid that is transparent to UV?
By the way, I also tried measuring UV through the glass windows in my house, and they reduce the UV measurement significantly also. (Not surprising.)
baqwas
Hello @garywil,
I've just started working with the MKR ENV shield. My initial "newbie" impressions are:
* it takes a "few" cycles for the UV readings to asymptote even under steady ambient conditions
* it will be challenging to use it in unattended mode a la weather station
Of course, I have a lot to learn and I'm ramping up but there are too many other distractions to do something with the data already under the belt.
Kind regards.
