Thanks Herb,
That suggestion was a path I didn't think of. I can find those transformers but it is still cheaper to find a 110/220 wall wart and rip out the transformer. I see multiple replies that the 1:2 transformer is very common but don't know why I can't find one. Seems like it should be readily available like mentioned by multiple folks and the many wall warts on ebay,google.
Waste of a good wall-wart. WallWarts rated at 85-265 Volts do NOT use a transformer, they use a switcher IC like the LNK304.
As others have said, your description is quite vague, so you will get vague answers. Please respond to the very first reply to your question.
" I have a specialty device that uses 24VAC, I also have a custom module that spits out 12VAC."
What is the "device" and what is the "module"? If you want good answers, provide good information.
