Looking in lib8tion.h:
- Beat generators which return sine or sawtooth waves in a specified number of Beats Per Minute.
Sine wave beat generators can specify a low and high range for the output. Sawtooth wave beat
generators always range 0-255 or 0-65535.
beatsin8( BPM, low8, high8) = (sine(beatphase) * (high8-low8)) + low8
beatsin16( BPM, low16, high16) = (sine(beatphase) * (high16-low16)) + low16
beatsin88( BPM88, low16, high16) = (sine(beatphase) * (high16-low16)) + low16
BPM is beats per minute in either simple form e.g. 120, or Q8.8 fixed-point form.
BPM88 is beats per minute in ONLY Q8.8 fixed-point form.
// beatsin8( BPM, uint8_t low, uint8_t high) returns an 8-bit value that
// rises and falls in a sine wave, 'BPM' times per minute,
// between the values of 'low' and 'high'.
// beatsin16( BPM, uint16_t low, uint16_t high) returns a 16-bit value
// that rises and falls in a sine wave, 'BPM' times per
// minute, between the values of 'low' and 'high'.
// beatsin88( BPM88, ...) is the same as beatsin16, except that the
// BPM88 argument MUST be in Q8.8 fixed point format,
// e.g. 120BPM must be specified as 120*256 = 30720.
// BPM can be supplied two ways. The simpler way of specifying BPM is as
// a simple 8-bit integer from 1-255, (e.g., "120").
// The more sophisticated way of specifying BPM allows for fractional
// "Q8.8" fixed point number (an 'accum88') with an 8-bit integer part and
// an 8-bit fractional part. The easiest way to construct this is to multiply
// a floating point BPM value (e.g. 120.3) by 256, (e.g. resulting in 30796
// in this case), and pass that as the 16-bit BPM argument.
// "BPM88" MUST always be specified in Q8.8 format.
/// beatsin88 generates a 16-bit sine wave at a given BPM,
/// that oscillates within a given range.
/// For this function, BPM MUST BE SPECIFIED as
/// a Q8.8 fixed-point value; e.g. 120BPM must be
/// specified as 120*256 = 30720.
/// If you just want to specify "120", use beatsin16 or beatsin8.
LIB8STATIC uint16_t beatsin88( accum88 beats_per_minute_88, uint16_t lowest = 0, uint16_t highest = 65535,
uint32_t timebase = 0, uint16_t phase_offset = 0)
/// beatsin16 generates a 16-bit sine wave at a given BPM,
LIB8STATIC uint16_t beatsin16( accum88 beats_per_minute, uint16_t lowest = 0, uint16_t highest = 65535,
/// beatsin8 generates an 8-bit sine wave at a given BPM,
LIB8STATIC uint8_t beatsin8( accum88 beats_per_minute, uint8_t lowest = 0, uint8_t highest = 255,
uint32_t timebase = 0, uint8_t phase_offset = 0)
My question - how to specify BPM parameter (not a BPM88!) in beatsin8() and beatsin16() less than 1 beat-per-minute (or other fractional value)? If it is not possible - what is the reason to use type accum88 there?
Can someone explain this sentence: "The more sophisticated way of specifying BPM allows for fractional "Q8.8" fixed point number (an 'accum88') with an 8-bit integer part and an 8-bit fractional part. The easiest way to construct this is to multiply a floating point BPM value (e.g. 120.3) by 256, (e.g. resulting in 30796 in this case), and pass that as the 16-bit BPM argument."
