Topic: take out a potentiometer (Read 1 time) previous topic - next topic
yoArduino
hi guys
I got this code from internet and it works well for my puppet ; anyway i'd like to take out the potentiometer "eyelid contro" which i don't need.
could you help me on the code pls ?
Code: [Select]
 Controlling a servo position using a potentiometer (variable resistor)
 by Michal Rinott <http://people.interaction-ivrea.it/m.rinott>
 modified on 8 Nov 2013
 by Scott Fitzgerald
 http://www.arduino.cc/en/Tutorial/Knob
#include <Servo.h>
Servo x;  // create servo object to control a servo
Servo y;
Servo b;
Servo t;
int xpotpin = 1;  // analog pin used to connect the potentiometer
int ypotpin = 0;
int opin = 2;
int bpin = 10;
int xval;    // variable to read the value from the analog pin
int yval;
int bval;
int tval;
int xxval;
int yyval;
int oval;
int blinkval;
  pinMode(bpin, INPUT);
  x.attach(8);  // attaches the servo on pin 9 to the servo object
  y.attach(9);
  b.attach(6);
  t.attach(7);
  blinkval = digitalRead(bpin);
  oval = analogRead(opin);
  xval = analogRead(xpotpin);            // reads the value of the potentiometer (value between 0 and 1023)
  yval = analogRead(ypotpin);
  oval = map(oval, 0, 1023, -10, 10);
  xxval = map(xval, 0, 1023, 0, 80);     // scale it to use it with the servo (value between 0 and 180)
  yyval = map(yval, 0, 1023, 0, 80);
  if (blinkval == 0){
    bval = 50;
    tval = 50;
    b.write(bval);
    t.write(tval);
  bval =  map(yval, 0, 1023, 110, 150);
  tval =  map(yval, 0, 1023, 120, 90 );
  b.write(bval + oval);
  t.write(tval + oval);
  x.write(xxval);                  // sets the servo position according to the scaled value
  y.write(yyval);
  delay(5);                           // waits for the servo to get there
slipstick
There are at least 3 pots and 4 servos in that code. None of them have any comments saying what they control so it's anyone's guess what "eyelid contro" is associated with.
Steve
surveyranger
#2
May 11, 2020, 07:57 pm Last Edit: May 11, 2020, 08:00 pm by surveyranger
Looks like the eyelid control pot (called opin) is connected to A2.
