Topic: react on incomming messages (SOLVED) (Read 2822 times) previous topic - next topic
jarivds_010
May 19, 2020, 09:32 am Last Edit: May 26, 2020, 09:40 am by jarivds_010
Here is the problem. I have build a ttn network based project. I can send to the things network which will send it over http to a php file and then to a database. But when I send a message back it gets back the whole way to the arduino but i don't know how I can do something with that data. In the lora send and recieve tutorial you can only read out messages in your serial monitor. How can I transform that incomming message to a function. For example put a led on and off.
here is my recieving part of the code:
Code: [Select]
if (!modem.available()) {
      Serial.println("No downlink message received at this time.");
  char rcv[64];
  int i = 0;
  while (modem.available()) {
    rcv[i++] = (char)modem.read();
  Serial.println("Received: ");
  for (unsigned int j = 0; j < i; j++) {
    Serial.print(rcv[j] >> 4, HEX);
    Serial.print(rcv[j] & 0xF, HEX);
    Serial.print(" ");
From this part I tried something but this doesn't work. You see what i'm trying to do?
Code: [Select]
  char cont = Serial.read();
  Serial.println(cont);
  if(cont == 'exact message I send from ttn'){
    digitalWrite(flitser, HIGH);
    digitalWrite(sirene, HIGH);
jarivds_010
jarivds_010
#2
May 26, 2020, 09:38 am Last Edit: May 26, 2020, 09:41 am by jarivds_010
I fixed the problem. Was quite simple, but didn't know how to do it
Code: [Select]
rcv = (byte)modem.read();
Serial.println(rcv);
if(rcv == 116){
digitalWrite(flitser, LOW);
digitalWrite(sirene, LOW);
So I read what the recieved number is and if that is the same in a byte format you can trigger the parts
