Topic: Does LM2596S module input voltage affect output voltage? (Read 100 times) previous topic - next topic
darth_chikoo
Hi.
I am trying to make a 5v Arduino speedometer for a bicycle. It is powered by a dynamo, that provides dc output.
As I am powering it with a dynamo, I know that the power will vary according to my cycling speed (but always higher than 7v).But however much power there is, I want a constant 5v output. I have considered using a linear voltage regulator but they are too inefficient. But I want to know that if the input voltage varies on a LM2596S buck converter module, will the output voltage also vary?
Thank you.
Paul__B
It is not supposed to!
That is why it is called a "regulator"!  :smiley-roll:
MarkT
In datasheets the "Line regulation" specification is the one saying how much effect the input voltage has
on the output.  This will be a fraction of a percent for most regulators.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
