Topic: Cheapest way to program standalone project (Read 11957 times) previous topic - next topic
simplesi
I've just bought a starter kit that came with an Arduino Uno and I'd like to build a standalone version of an IR Transcoder  Sketch (to make my TV remote control my DVD player) and it seems I can't use it to directly program a standalone ATMega 328 chip because of a unresolved software issue with the UNO optiboot bootloader  :(
As a family man with a strict budget for my toys :) I'd like to know what the cheapest way to get my sketch from a Uno onto a standalone project.
Any ideas please :)
regards
Simon
PS Loving Arduino :)
westfw
There are several ways of disabling auto-reset when using ArduinoISP with an Uno.
Search the forums for other "bootloader" posts.
simplesi
@drew - thats the right price :)  but are there any instructions on how to use one (or a compatbile equivalent) to upload a Uno sketch with it?
@westfw - I've found a few (I've even found a post saying that the Uno does work with ArduinoISP!) - have you got a link to one you used yourself?
regards
Simon
CrossRoads
Are you in the US?
I'm using this one.
http://www.mdfly.com/index.php?main_page=product_info&cPath=5&products_id=415
Here it is in action programming my '1284 based "Bobuino"
Add these 2 lines to programmers.txt after download/install the driver, link is on the same page.
usbasp.name=MDFLY
usbasp.protocol=usbasp
(deleted)
#5
Aug 06, 2011, 11:53 pm Last Edit: Aug 07, 2011, 12:32 am by spycatcher2k Reason: 1
(deleted)
simplesi
@drew and crossroads - ta very much :)
Simon
dc42
#7
Aug 09, 2011, 11:03 am Last Edit: Aug 09, 2011, 11:13 am by dc42 Reason: 1
I've just moved a sketch from Arduino Uno to a virgin processor in my own hardware, using the Arduino Uno itself as a programmer. See http://miscsolutions.wordpress.com/2011/08/09/prototyping-small-embedded-projects-with-arduino/.
simplesi
@dc42
I was hoping there was someway to it without addtional hardware (discounting the capacitor or course :)
My barebone kits of parts has arrived so I'll give your method a go tomorrow and let you know how I got on :)
Simon
CrossRoads
This has to be one of the least expensive USB AVR programmers I have seen.
http://www.nkcelectronics.com/pocket-avr-programmer.html
I just received one today.  Comes with a 10-pin to 6-pin cable to  plug onto ICSP pins as well.
retrolefty
Cheapest method has to be:
1. Upload sketch to your arduino Uno board.
2. Remove 328p chip from Uno and install it in your standalone project 28 pin DIP socket.
3. Purchase replacement $6 328p chip with bootloader and install it into the Uno board.
Lefty
simplesi
I wish my Uno had come like that but it came with a square chip soldered directly to the board :(
Simon
retrolefty
Simon
The is because you have a Uno SMD model, and that is unfortunate. I think I read that they came out with the Uno SMD model because there was a shortage of 328p chips in the DIP package so they started building Uno SMD boards until the supply situation improved. Now they seem to offer both Uno and Uno SMD boards? Not sure if that is all true or not, but as long as the standard DIP version of the Uno is avalible I see no reason in the world one should buy the SMD version.
Lefty
Bobnova
ArduinoISP and bare new chips is cheaper than buying pre-bootloader'd chips.  Chips w/bootloader are definitely the easiest.
Techone
@simplesi
I know how you feel to be on a low budget. The cheapest way that I am thinking is to get : USB-to-TTL adapter, an ATmega328 with pre-loaded bootloader , a 16 MHz crystal and wires. Check this site to how to do it : http://www.dalewheat.com/
The company that I shop for Arduino & PICAXE : http://www.robotshop.com/ca/ but they don't have crystal ( Located in Montreal, Quebec and they have store in the US ) and http://www.hvwtech.com/, they carry crystals, ZIP <-- Zero-Insertion-Socket ( located in Calgary , Alberta )
The only part you need to purchase once is the USB-TTL adapter.
I hope this help.
