Topic: Silicon diode as voltage step down  (Read 757 times) previous topic - next topic
PerryBebbington
Well, I'm planning to use Mini Automotive Blade Fuse. Is it ok or HRC fuses must be used?
I personally think automotive blade fuses are horrible things, but they seem to do their job so maybe I am just expressing a personal preference. For ~14V I don't think you are going to sustain an arc if the fuse blows, so probably OK. For higher DC voltages I would only consider a HRC fuse to ensure any arc is extinguished (they have quartz sand (or something) in them).
larryd
The neighbour lady installed two 'silicone' ones they work just fine.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
Paul__B
Can't say I would be entirely happy with the dynamics, I would be very suspicious of the "feel" of the interface.  :smiley-roll:
larryd
#18
Jun 01, 2020, 01:58 am Last Edit: Jun 01, 2020, 01:58 am by larryd
Being married, can only look from a distance. ???
No technical PMs.
raschemmel
I have some hands on experience in that area.
It's pretty subjective ...
Tom-4
What do u mean?
raschemmel
#21
Jun 01, 2020, 06:18 am Last Edit: Jun 01, 2020, 06:22 am by raschemmel
If you have to ask... you're too young.
AJLElectronics
Only skim read this thread, but is there any reason why a buck/boost regulator could not feed a decent pass transistor for the current?
Tom-4
Simply.... there's no reliable and cheap buck converter which can handle 8 amp job!
6v6gt
Post #11 clearly contradicts this. Maybe @PerryBebbington can provide some links. I'm also curious about this.
AJLElectronics
You might like to re-read my response?
AJLElectronics
I still say we need a "like" button. ;-)
PerryBebbington
I really don't see the need, I typed buck boost converter 10A into Amazon and got loads of them, some under £10. No idea if they are reliable...
As you seem unable to do this here's an example, there are loads more buck boost 10A
Tom-4
I don't trust shity Chinese things on amazon, eBay or on whatever it is.
AJLElectronics
I would agree with you Perry. I am sure that the original design with quality manufacture was fine, but the aftermarket fuses are nothing short of horrible. A main part of my business is restoration of classic cars and I have lost count of the number of melted fuses I have seen. That's not melted wire, but a blob of molten plastic caused by a slightly corroded socket.
They are only surpassed in "horribleness" by Inch and quarter glass fuses. Again, no issue with quality manufacture, but the Prince of Darkness replacement fuseboxes have spring ears which don't and the fuse element in aftermarket fuses is often disconnected at one end inside the cap where you can't see it.
I'm not sure what the answer is, frankly.
