Topic: Stepper motor final position is shifted left in every cycle (Read 643 times) previous topic - next topic
global1
I try to write a code to run stepper motor which turns desired steps and stops for desired period. Each step and stop period movement is a one cycle and I also attached desired cycle into code. Surprisingly it works fine rather than a problem. İn every 2 cycle(1 forward and 1 backward), final position slightly shift left from initial start position. I could not solve the problem.Can anyone help me to solve it? You can check the shifted position from png file.
Code: [Select]
#include <Arduino.h>
#include <AccelStepper.h>
AccelStepper stepper(1, 50, 52);
int speed = 5000; //set speed
int acc = 5000; //set accelearation
int incCount = 20; // Desired step in a cycle
unsigned long count = 0; //Step Count
unsigned long katCount = 0; //Cycle Count
int state; //0= running 1=waiting
unsigned long timer;
const unsigned long delayTime = 50; //waiting time of the motor
unsigned long distance = 30; //
int layer = 100; //Total Cycle
  Serial.println("Testing accel");
  stepper.setMaxSpeed(speed);
  stepper.setAcceleration(acc);
  stepper.move(0);//start by moving
  if (katCount != layer) {
    if (state == 0) {
      if (stepper.distanceToGo() == 0) {
        state = 1;
        count = count + 1 ;
        if (count == incCount) {
          katCount = katCount + 1;
          count = 0;
          stepper.setSpeed(acc);
          distance = distance * (-1);
        timer = millis() + delayTime;
    } else { //state == waiting
      if (millis() >= timer) {
        state = 0;
        stepper.move(distance);
    stepper.run();
    Serial.println(katCount);
  else {
    stepper.stop();
    stepper.disableOutputs();
