Arduino Forum
Using Arduino
General Electronics
(Moderator:
PerryBebbington
Does an Analog Temperature Sensor Ever Equal a Negative Number?
Print
Pages:
[1]
Topic: Does an Analog Temperature Sensor Ever Equal a Negative Number?
(Read 134 times)
previous topic
next topic
ZebH
Sr. Member
[add]
Jun 09, 2020, 08:46 am
Hi all,
I am wondering if an analog temperature sensor ever equals a negative number? Does any analog sensor ever equal a negative number?
Thanks,
Zeb
One of the most common programming problems is a misplaced/missing bracket.
Riva
Faraday Member
[add]
Re: Does an Analog Temperature Sensor Ever Equal a Negative Number?
#1
Jun 09, 2020, 09:42 am
Not sure what you mean but the Analogue pin will not read negative voltages and you should avoid feeding any pins with negative voltages.
The analogue temperature sensor reporting temperatures lower than zero is possible because some of them have a zero degree output of > 0 volt. As an example the TMP35 can read in the range -40C to +150C and outputs 0.1V at -40C and 2V at 150C.
Don't PM me for help as I will ignore it.
ZebH
Sr. Member
[add]
#2
Jun 09, 2020, 10:01 am
Ah I see! Thanks very much for your help!
Zeb
Print
Pages:
[1]
Loading...
