Arduino Forum
Using Arduino
General Electronics
(Moderator:
PerryBebbington
Schmitt trigger weird behaviour
Print
Pages:
[1]
Topic: Schmitt trigger weird behaviour
(Read 279 times)
previous topic
next topic
SwengX
Newbie
[add]
Jun 09, 2020, 02:18 pm
Last Edit
: Jun 09, 2020, 05:35 pm by SwengX
Hello,
I have a project where I use
this
exact schmitt trigger to debounce a pushbutton. When I push the button nothing happens at the digital pin on the Arduino. I think it just floats. Actually, I use an embedded Atmega328. When I press the Atmega a bit with my finger, the state of the pin changes from 0 to 1 or vice versa regardless of the state of the pushbutton. So far, this looks like a floating pin. I measured the voltages, the schmitt trigger output pin was ok (5V), and I made a continuity test from the output to the arduino digital pin and it was also good. However, I can't measure 5V on the arduino digital pin. The voltage just goes away?! Then, I noticed that when I connect my multimeter between the schmitt trigger output and GND, everything works fine. What causes this? I hope it is nothing serious because it is quite hard to modify the circuit on the pcb.
Smajdalf
Edison Member
[add]
Re: Schmitt trigger weird behaviour
#1
Jun 09, 2020, 03:29 pm
Try to resolder the Schmitt IC - at least the output pin. I seems you get it working everyone you press it to the PCB improving contact.
How to insert images:
https://forum.arduino.cc/index.php?topic=519037.0
dlloyd
Faraday Member
[add]
https://www.tindie.com/stores/dlloyd/
#2
Jun 09, 2020, 08:42 pm
If you want the Arduino input to be normally low (high when button pressed) then perhaps your circuit connections are like this?
6v6gt
Tesla Member
[add]
Switzerland
#3
Jun 10, 2020, 06:22 am
You can, of course, debounce a button purely in software. Something like if you get a button press, ignore further activity from that button for the next , say, 100mS.
Print
Pages:
[1]
Loading...
