Topic: Sanitizer dispenser code help (Read 3045 times) previous topic - next topic
TheMemberFormerlyKnownAsAWOL
Sorry, It should be
else {
    digitalWrite (6, LOW);
    priState = false;
No, it should be
digitalWrite (pumpPin, LOW);
Please don't PM technical questions - post them on the forum, then everyone benefits/suffers equally
vinodamarathunga
D PIN 6 is the Relay Control Input na d I have not defined any pumpIN variable in my code.
You should
Reason ?
It's a great habit to learn.
And it makes boo-boos like
digitalWrite (5, LOW); even easier to spot, fix or modify.
vinodamarathunga
Yes, Got it,
you mean defining the pins, good practice indeed
souravrout9
Friends
Request you all to help me by sharing a code for automatic hand sanitizer based on ultrasonic sensor,5v relay, 5 v DC pump and Arduino-Nano
mehpako
Hi
Is it possible for me to have the complete code of the program and
if I want to use the FC-51 ir module, what will be the code changes?
I had exactly the same problem.
