Topic: WiFi101WebThingAdapter (Read 340 times) previous topic - next topic
dr_esi
Sorry to disturb you on a Sunday afternoon  ;)
I stumbled over some .h-files when trying to run the following example code:
Code: [Select]
#define LARGE_JSON_BUFFERS 1
#include <Arduino.h>
#include <Thing.h>
#include <WebThingAdapter.h>
#ifdef ESP32
#include <analogWrite.h>
#endif
const char *ssid = "....";
const char *password = "..........";
#if defined(LED_BUILTIN)
const int lampPin = LED_BUILTIN;
#else
const int lampPin = 13; // manually configure LED pin
#endif
ThingActionObject *action_generator(DynamicJsonDocument *);
WebThingAdapter *adapter;
const char *lampTypes[] = {"OnOffSwitch", "Light", nullptr};
ThingDevice lamp("urn:dev:ops:my-lamp-1234", "My Lamp", lampTypes);
ThingProperty lampOn("on", "Whether the lamp is turned on", BOOLEAN,
                     "OnOffProperty");
ThingProperty lampLevel("brightness", "The level of light from 0-100", INTEGER,
                        "BrightnessProperty");
StaticJsonDocument<256> fadeInput;
JsonObject fadeInputObj = fadeInput.to<JsonObject>();
ThingAction fade("fade", "Fade", "Fade the lamp to a given level",
                 "FadeAction", &fadeInputObj, action_generator);
ThingEvent overheated("overheated",
                      "The lamp has exceeded its safe operating temperature",
                      NUMBER, "OverheatedEvent");
bool lastOn = true;
void setup(void) {
  pinMode(lampPin, OUTPUT);
  digitalWrite(lampPin, HIGH);
  Serial.println("");
  Serial.print("Connecting to \"");
  Serial.print(ssid);
  Serial.println("\"");
#if defined(ESP8266) || defined(ESP32)
  WiFi.mode(WIFI_STA);
#endif
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  adapter = new WebThingAdapter("led-lamp", WiFi.localIP());
  lamp.description = "A web connected lamp";
  lampOn.title = "On/Off";
  lamp.addProperty(&lampOn);
  lampLevel.title = "Brightness";
  lampLevel.minimum = 0;
  lampLevel.maximum = 100;
  lampLevel.unit = "percent";
  lamp.addProperty(&lampLevel);
  fadeInputObj["type"] = "object";
  JsonObject fadeInputProperties =
    fadeInputObj.createNestedObject("properties");
  JsonObject brightnessInput =
    fadeInputProperties.createNestedObject("brightness");
  brightnessInput["type"] = "integer";
  brightnessInput["minimum"] = 0;
  brightnessInput["maximum"] = 100;
  brightnessInput["unit"] = "percent";
  JsonObject durationInput =
    fadeInputProperties.createNestedObject("duration");
  durationInput["type"] = "integer";
  durationInput["minimum"] = 1;
  durationInput["unit"] = "milliseconds";
  lamp.addAction(&fade);
  overheated.unit = "degree celsius";
  lamp.addEvent(&overheated);
  adapter->addDevice(&lamp);
  adapter->begin();
  Serial.println("HTTP server started");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.print("/things/");
  Serial.println(lamp.id);
#ifdef analogWriteRange
  analogWriteRange(255);
#endif
  // set initial values
  ThingPropertyValue initialOn = {.boolean = true};
  lampOn.setValue(initialOn);
  (void)lampOn.changedValueOrNull();
  ThingPropertyValue initialLevel = {.integer = 50};
  lampLevel.setValue(initialLevel);
  (void)lampLevel.changedValueOrNull();
  analogWrite(lampPin, 128);
  randomSeed(analogRead(0));
void loop(void) {
  adapter->update();
  bool on = lampOn.getValue().boolean;
  if (on) {
    int level = map(lampLevel.getValue().number, 0, 100, 255, 0);
    analogWrite(lampPin, level);
    analogWrite(lampPin, 255);
  if (lastOn != on) {
    lastOn = on;
It throws the following error:
libraries\webthing-arduino/WiFi101WebThingAdapter.h:27:10: fatal error: ArduinoMDNS.h: No such file or directory
 #include <ArduinoMDNS.h>
I tried to mend it following the suggestion of Jurai: https://forum.arduino.cc/index.php?topic=603001.0
this results then in the error:
'MDNS' does not name a type
   MDNS mdns;
So I guess ArduinoMDNS.h is needed: Dead end.
But I m not sure where to dig now.
Any hints or indication where my mistake lies would be appreciated.
Cheers
dr_esi
Some progress here:
I re-installed the ArduinoMDNS.h and this brought me one step further.
But the amount of error messages just exploded, over some JSON problem. Here just an extract with the effective error messages:
\Arduino\libraries\ArduinoJson\src/ArduinoJson/Variant/VariantFunctions.hpp:135:3: error: static assertion failed: To use 64-bit integers with ArduinoJson, you must set ARDUINOJSON_USE_LONG_LONG to 1. See https://arduinojson.org/v6/api/config/use_long_long/
   ARDUINOJSON_ASSERT_INTEGER_TYPE_IS_SUPPORTED(T);
\ArduinoJson\src/ArduinoJson/Variant/VariantAs.hpp:58:3: error: static assertion failed: To use 64-bit integers with ArduinoJson, you must set ARDUINOJSON_USE_LONG_LONG to 1. See https://arduinojson.org/v6/api/config/use_long_long/
exit status 1
Error compiling for board Arduino Uno.
what I also found out is that I installed the webthing-arduino library instead of the webthing library, as described on mozilla's homepage: https://iot.mozilla.org/framework/
I did not find a webthing library though on https://www.arduinolibraries.info/libraries
Still digging
dr_esi
Ok, figured out something more, according to https://arduinojson.org/v6/api/config/use_long_long/ I had to introduce
#define ARDUINOJSON_USE_LONG_LONG 1
just above
#include <ArduinoJson.h>
 in file Thing.h, which is located in the "webthing-arduino"-folder.
But it doesn't won't to start because of this, next error:
\AppData\Local\Temp\ccX8IYT4.ltrans0.ltrans.o: In function `global constructors keyed to 65535_0_WebthingsTes.ino.cpp.o.6136':
<artificial>:(.text.startup+0x37a): undefined reference to `action_generator(ArduinoJson6152_1000010::BasicJsonDocument<ArduinoJson6152_1000010::DefaultAllocator>*)'
<artificial>:(.text.startup+0x37c): undefined reference to `action_generator(ArduinoJson6152_1000010::BasicJsonDocument<ArduinoJson6152_1000010::DefaultAllocator>*)'
collect2.exe: error: ld returned 1 exit status
I run
webthing version 0.11.5
Arduino JSON version 6.15.2 (eventhough this video shows it with version 5 and it's mentioned that version 6 wouldn't work, I tried both and version 5 throws the error that some JSON objects are only within version 6)
So, looking for the next solution.
Cheers
dr_esi
Ok, I adressed the same topic at Mozillas WebThings Forum.
You can find the answer there, the example was incomplete...
Btw the readme example works.
