Topic: Arduino controlled electromagnet, LED, and audio (Read 731 times) previous topic - next topic
sambu31
Hi everyone,
I am a university student working on what I would imagine is a fairly straightforward electronics project for someone with experience. However, with my lack of knowledge I have been struggling to understand what components I need.
I want to control a single electromagnet, an LED strip and have audio output run from a single Arduino board at the same time.
I would like to know what components would I need to successfully achieve this? As of now, I have not purchased any components so there are no specifics to the project yet.
If anyone would be willing to guide me and offer support throughout the short project, I would happily offer compensation for the help.
If you have any questions let me know!
Thanks in advance!
spycatcher2k
You are going to have to do a lot better in your description.
Define 'Audio'
Define what LED you think you need
Define what Electromagnet you are trying to use
No - I'm not interested in doing this.
Mrs Drew
UK Based PCB Manufacturing - PM for details
I will design & code for you, but I will also charge you (PM me)
Use Google or search this site BEFORE asking!
sambu31
Whatever small (50 - 80mm diameter) audio speaker which can be used with an arduino.
Once again, no specific LED strip. However, I found this one on amazon which should do (as long as its compatible with arduino):
https://www.amazon.co.uk/CHINLY-WS2812B-Individually-addressable-Waterproof/dp/B07TPSB35N/ref=sr_1_5?dchild=1&keywords=arduino+led+strip&qid=1592856866&sr=8-5
An electromagnet between 20/40mm in diameter should do just fine with a fairly small pull as it will only be used to interact with some ferrofluid, for reference this one can be used:
https://www.amazon.co.uk/Magnet-Expert-Rubber-Coated-Neodymium/dp/B077T2YPGW/ref=sr_1_7?dchild=1&keywords=electromagnet+20mm&qid=1592857199&sr=8-7
I am mainly struggling to know which components such as flyback diodes, transistors or control units I need for the circuit to run successfully and safely.
