Topic: Uno dead .. only green led how to troubleshoot ? (Read 1 time) previous topic - next topic
fca
Aug 13, 2011, 01:38 am Last Edit: Aug 13, 2011, 02:00 am by fca Reason: 1
hi my arduino start to loose usb connectivity a few days a go when i issued a digital pin high that is connected to relay ( i will open another topic about the project itself) then i did power on/ power off and then it start to work.. but now is dead,  only green led turns on...
I already tried with the atmega off and not even the serial port appears... I know the the atmega must be also dead (I already installed the atmega on  working arduino and didn't  work also, i want to try to understand what happened...
Question:how can i investigate what is burned/damaged ? the usb2serial , the crystal what ?
thanks & regards.
Check what this arduino was doing here:
http://arduino.cc/forum/index.php/topic,69266.0.html
fca
hi,
i finally had time to  try to revive this board ..
tha atmega is dead for sure and the usb part also...
So i programmed a atmega on another arduino that make some leds blink , remove the programmed atmega and put it on the "damaged" board...
Guess what it works...
the usb chip must be burned..
i will order another atmega328 with bootloader, now how could i flash the arduino will a ttl to usb connected on pin0,1 will be enough to upload sketches ?
thanks
retrolefty
Quote
Yes that can work, although most of the ttl to usb serial converter cables don't support the Arduino DTR auto-reset function. Here is one that is easily modded to provide auto-reset.
http://www.ebay.com/itm/370532286388?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
fca
great, i will order one ..
so i connect tx ->rx  + rx->tx ....
how about the auto dtr ? what do i need to do ?
regards.
retrolefty
Also connect ground to ground
and RST to arduino reset pin if you do the mod below.
For that specific device there is a open hole pad labled DTR, wire a .1 ufd cap from that pad to the base of the RST pin on the connector. Then turn the board over and cut the trace that was going to the RST pin of the connector. Then just add another jumper wire from the RST pin to the Arduino reset pin and it will work as the original board did.
Lefty
retrolefty
Also connect converter ground to arduino ground
Lefty
