Hello AnyCubic Delta / RAMPS users,
I have posted some stuff elsewhere regarding 'Loss of accuracy and position' during printing. I think I have solved those problems after stripping out all the old Arduino junk files and downloading 1.8.13 via the Windows app. rather than the .zip file. This has worked well so far and seems to be well sorted out.
The file removal process described by 'pert' and others has worked well in purging some very persistent bugs from many earlier downloads. I think it's a good tactic to start afresh when patience is at an end.
However...
During test prints the printer runs well but then abruptly stops and displays 'Error min temp' Please Reset.
This has happened a few times now, after about ten minutes of printing.
The motors are cool, the TMC2208s are running at 46 Deg C and the heated bed and effector temperature readings on the LCD display are rock steady at 60 degrees and 200 degrees respectively.
I have looked through the forum but I can't find any reference to this particular glitch.
I have checked over all the obvious possibilities but I would appreciate any observations from anyone who has had similar irritations.
Thanks in advance.
Scintilla.
