Topic: AD7152 TO Arduino (Read 231 times) previous topic - next topic
nthu
Hello everyone, I am using EVAL-AD7152 to get the capacitance data from a 2pF ceramic capacitor, but the Arduino can not read the capacitance value of AD7152, I use 3.3V arduino mega2560 as my master device, and my slave device is 3.3V. Below is my code.
#include <Wire.h>
#define AD7152_I2C_ADDRESS 0x48               //AD7152 adress
#define AD7152_REG_STATUS 0x00
#define AD7152_REG_CH1_DATA_MSB 0x01
#define AD7152_REG_CH1_DATA_LSB 0x02
#define AD7152_REG_CH1_SETUP 0x0B
#define AD7152_REG_CONFIGURATION 0x0F
byte myArray[] = {219, 0, 0, 0, 49, 0, 255};    //SETUP Reg, x, x, x, CONFIG REg
  Wire.begin();
  Wire.beginTransmission(AD7152_I2C_ADDRESS);
  Wire.write(AD7152_REG_CH1_SETUP);          //Move pointer to the SETUP register address
  Wire.write(myArray, sizeof(myArray));  //see global arry declaration
  byte busStatus = Wire.endTransmission();
  delay(4);
  if(busStatus !=0)
    Serial.println("I2C Communication problem....!");
    while(1);      //wait for ever
  Wire.beginTransmission(AD7152_I2C_ADDRESS);   // "Hey, AD7152 @ 0x48! Message for you"
  Wire.write(AD7152_REG_STATUS);     //pointing Status Register
  delay(4);
  do
      Wire.requestFrom(AD7152_I2C_ADDRESS, 1); //if conversion complete, we can read data bytes also
  while(Wire.read() != 0x52);     //at busy--Wire.read() = Status Register 0x53; else Wire.read() = 0x52
  Wire.write(AD7152_REG_CH1_DATA_MSB);     //pointing DATA_H Register
  delay(4);
  Wire.requestFrom(AD7152_I2C_ADDRESS, 2);
  int ch1 = (int)Wire.read() <<8 | (int) Wire.read();
  float Cap1 = (ch1 - 0x8000) / 0xFFF0; //Converts digital value into capacitance, formula from datasheet.
  //print the data on serial monitor
  Serial.print("Ch1="); Serial.print(ch1, BIN);
  Serial.print(" Ch1="); Serial.print(ch1, DEC);
  Serial.print(" C1="); Serial.println(Cap1, 4);
  delay(700);
trethbos
I'm really new to coding... so this may be nonsense, but for an Int the Arduino reference states
"On the Arduino Uno (and other ATMega based boards) an int stores a 16-bit (2-byte) value."
In your code you have
Doesn't ch1 need to be 4 bytes to work in your formula?
As said I'm learning, so I would like to know the answer.
