Topic: Atmega32u4 Invalid Device Signature (Read 370 times) previous topic - next topic
shai
Jun 29, 2020, 08:34 pm Last Edit: Jul 01, 2020, 11:02 pm by shai
I hope I'm in the right forum here, if not please point me where I can move this topic to!
I designed a custom board using Atmega32u4. I'm now trying to burn the Bootloader and getting the following error below.
I already quadruple checked my connections and they are correct because I was able to flash Bootloader onto a Atmega328P and simply plugged the same cable to this Atmega32u4 board. I tried burning with an Uno at first and then with a USB ISP from amazon. Getting the same error. I even made two of the same boards thinking perhaps it's a component or soldering issue. Same error. I tried both on iMac and Windows 10.
I'm choosing "Arduino as ISP" and Board: Leonardo. As mentioned, I was able to burn an Atmega328P successfully with the Uno. And yes, I have a 10uF cap between reset and GND.
I've attached my board/schematic. Only issue I noticed is I forgot to connect one of the crystal's GND pads, but I jumped it later on.
Any help would be really appreciated as I'm at my wits end with this. I searched forums and tutorials for over a week. Thank you!
Code: [Select]
Arduino: 1.8.12 (Mac OS X), Board: "Arduino Leonardo"
/Users/shaischechter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/shaischechter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega32u4 -cstk500v1 -P/dev/cu.usbmodem141401 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xcb:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xff:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/Users/shaischechter/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/Users/shaischechter/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem141401
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.02s
Reading | Error while burning bootloader.
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
option enabled in File -> Preferences.
m_k_akash
Are you sure that the atmega32u4 is not damaged ?
You asked me and I am here
shai
It's brand new from digikey. This is the exact one I bought: https://www.digikey.com/products/en?keywords=ATMEGA32U4-AU-ND
And as mentioned, I tried soldering two boards. I can't imagine that both boards got damaged same way that would cause this. Any other ideas? I really don't know what to do here to fix it and have the Bootloader uploaded.
m_k_akash
#3
Jun 30, 2020, 07:02 am Last Edit: Jun 30, 2020, 08:59 am by m_k_akash
could you post a jpg or png file of the diagram ? I recommend using the avrdude  externally or use avrdude's GUI version (avrdudess) and using usbasp run this command to get the signature
Code: [Select]
avrdude -u -c usbasp -P usb -B 0.5 -p m32u4
shai
Sorry which diagram are you referring to? The PCB schematic?
m_k_akash
shai
#6
Jun 30, 2020, 09:49 pm Last Edit: Jul 01, 2020, 11:02 pm by shai
Here you go. I attached it. I also tried burning Bootloader by making a 3rd board and only attaching the crystal with 18pF on each side (didn't have 22pF) and it still wouldn't Burn Bootloader.
kprims
Quote
Look at the ISP header on the Rapid Feeder. Your leads are not wired in a standard fashion for a 10 lead cable.
https://cdn.hackaday.io/images/6065901532707936157.png
shai
Yes it's not standard, but that doesn't matter because I connect each one individually and quadruple checked it.
shai
#9
Jul 01, 2020, 06:33 am Last Edit: Jul 01, 2020, 07:53 am by shai
See attached image. I have found the problem. Top is imported crystal of same part # from Samcasys public library plugin and bottom crystal is the one on the board that I made footprint of. It seems I may have accidentally swapped the crystal/GND connections...
