Topic: motor speed control (Read 145 times) previous topic - next topic
kevin1951
HI.
i'm new to Arduino, and at 69 years old am struggling to understand it.
i'm making"trying"to make  a robotic lawnmower, so far iv'e got most of it working, but i can't get to grips with slowing down the motors, i have two kids ride on car motors running at the moment.
this is the code iv'e downloaded.
#include <Servo.h>
// Pins
#define TRIG_PIN A0
#define ECHO_PIN A1
//Define all the connections maps to the L298N
#define enA 13
#define in1 12
#define in2 11
#define in3 7
#define in4 6
#define enB 5
#define servoPin 3
class Motor{
int enablePin;
int directionPin1;
int directionPin2;
public:
//Method to define the motor pins
Motor(int ENPin,int dPin1,int dPin2){
enablePin = ENPin;
directionPin1 = dPin1;
directionPin2 = dPin2;
//Method to drive the motor 0~255 driving forward. -1~-255 driving backward
void Drive(int speed){
if(speed>=0){
digitalWrite(directionPin1, LOW);
digitalWrite(directionPin2, HIGH);
else{
digitalWrite(directionPin1, HIGH);
digitalWrite(directionPin2, LOW);
speed = - speed;
analogWrite(enablePin, speed);
Motor leftMotor = Motor(enA, in1, in2);
Motor rightMotor = Motor(enB, in3, in4);
Servo myservo; // create servo object to control a servo
void motorInitiation(){
pinMode(enA, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
// Set initial direction and speed
digitalWrite(enA, LOW);
digitalWrite(enB, LOW);
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
//Variables--------------------------------------------------------------------------
// Anything over 400 cm (23200 us pulse) is "out of range"
const unsigned int MAX_DIST = 23200;
bool ObsticalAhead = false;
int servoPos = 90;
enum Directions { Forward, TurnLeft, TurnRight, TurnAround,Brake};
Directions nextStep = Forward;
unsigned long t1;
unsigned long t2;
unsigned long pulse_width;
float cm;
float inches;
//SETUP--------------------------------------------------------------------------
// The Trigger pin will tell the sensor to range find
pinMode(TRIG_PIN, OUTPUT);
digitalWrite(TRIG_PIN, LOW);
// We'll use the serial monitor to view the sensor output
myservo.attach(servoPin);
motorInitiation();
checkDistance();
checkDirection();
drive();
void checkDistance(){
// Hold the trigger pin high for at least 10 us
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
// Wait for pulse on echo pin
while ( digitalRead(ECHO_PIN) == 0 );
// Measure how long the echo pin was held high (pulse width)
// Note: the micros() counter will overflow after ~70 min
t1 = micros();
while ( digitalRead(ECHO_PIN) == 1);
t2 = micros();
pulse_width = t2 - t1;
// Calculate distance in centimeters and inches. The constants
// are found in the datasheet, and calculated from the assumed speed
//of sound in air at sea level (~340 m/s).
cm = pulse_width / 58.0;
inches = pulse_width / 148.0;
// Print out results
if ( pulse_width > MAX_DIST ) {
//Serial.println("Out of range");
//Serial.print(cm);
//Serial.print(" cm \t");
//Serial.print(inches);
//Serial.println(" in");
// Wait at least 60ms before next measurement
delay(60);
if(cm<= 20){
ObsticalAhead = true;
Serial.println("Problem Ahead");
else{ ObsticalAhead = false;}
void checkDirection(){
Serial.println("checking direction");
if(ObsticalAhead ==true){
nextStep = Brake;
drive();
myservo.write(180); // tell servo to go to position in variable 'pos'
delay(400); // waits 15ms for the servo to reach the position
checkDistance();
if(ObsticalAhead ==false){//if left side is open
nextStep = TurnLeft;
Serial.println("Next step is TurnLeft");
myservo.write(90);//reset servo position
delay(400);
else{// left is blocked, now need to look at right
myservo.write(0); // tell servo to go to position in variable 'pos'
delay(800); // waits 15ms for the servo to reach the position
checkDistance();
if(ObsticalAhead ==false){//if right side is open
nextStep = TurnRight;
Serial.println("Next step is TurnRight");
delay(400);
else{//right is blocked as well, need to turn around
nextStep = TurnAround;
delay(300);
Serial.println("Next step is TurnAround");
else{nextStep = Forward;}//No obstical ahead
void drive(){
switch (nextStep){
case Forward:
leftMotor.Drive(255);
rightMotor.Drive(255);
Serial.println("Forward");
case TurnLeft:
leftMotor.Drive(-255);
Serial.println(" TurnLeft");
delay(400);
case TurnRight:
rightMotor.Drive(-255);
Serial.println(" TurnRight");
delay(400);
case TurnAround:
Serial.println(" TurnAround");
delay(600);
case Brake:
leftMotor.Drive(0);
rightMotor.Drive(0);
Serial.println(" stopped");
I realise that i am totally out of my depth, but nevertheless i would still appreciate some assistance.
wildbill
How do you plan to specify the speed?
Is it supposed to run at different speeds or do just want it running at a speed slower than it does now?
johnwasser
Code: [Select]
t1 = micros();
t2 = micros();
All of this can be replaced with:
Code: [Select]
pulse_width = puleIn(ECHO_PIN, HIGH, MAX_DIST);
And the NewPing library can handle all of the low-level stuff for you and deliver distances in cm.
One problem with the code as written.  If no echo is seen the Echo pin will never go HIGH and your first while() loop will hang forever.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
slipstick
You forgot to say which Arduino you are using. Pin13 isn't a PWM pin on many of them so analogWrite won't do what you expect.
What exactly are the motors you are using because an L298N will only run small motors (and not very well). "Kids ride on car motors" sound like they will be way too big.
Steve
kevin1951
Thanks for the replies, I'm using an Arduino Uno, I just need to lower the speed in both directions, also using two 12000 rpm 12v motors.
slipstick
O.k. you need to move enA to a different pin. Valid PWM pins for speed control are 3, 5, 6, 9, 10, 11.
12000rpm 12V isn't really a motor specification. Do you have a link to the motors you're using?
Steve
JCA34F
What are the full load and stall current of those motors?
wildbill
Change the number you pass to analogWrite (after you've redone the wiring as suggested). Try 128 to start with and experiment with it until you get the speed you need. Be aware that at some point, the number will be too low to move the motors at all.
slipstick
Sorry, just noticed you're using Servo.h so that means you can't use PWM on pins 9 and 10 either. So enA needs to be on one of 3,5,6 or 11.
Steve
