Topic: How to make arduino code permanently (Read 362 times) previous topic - next topic
fauzian
how to make arduino code permanently?
the program :
Code: [Select]
#include<EEPROM.h>
#define address_DeviceID 1
#define address_InterValSending 5
/************ubah parameter disini************/
String  strDeviceID = "HGT07";      //maksimal 5 karakter
uint8_t interval      = 5;          //dalam satuan menit
String  strDummy      = "";
char    charBuf[10];
char    kar;
int     value         =0;
   //tulis device id ke eeprom
   for(uint8_t i=0;i<=strDeviceID.length()-1;i++){
        strDummy=strDeviceID.substring(i,i+1);
        strDummy  .toCharArray(charBuf,10);
        kar=charBuf[0];
        value=(int)kar;
        EEPROM.write(1+i,value);
   strDummy="";
   //richek
   for(uint8_t i=1;i<=5;i++){
      strDummy+=(String)(char)(EEPROM.read(i));
   if(strDummy==strDeviceID){
    Serial.println("Sukses Tulis Data");
    Serial.println(strDummy);
   }else{
    Serial.println("GAGAL Tulis Data");
   //tulis interval sending
   EEPROM.write(10,interval);
   if(EEPROM.read(10)==interval){
    Serial.println("Tulis Interval Sukses");
    Serial.print(EEPROM.read(10));Serial.print(" Menit");
    Serial.println("");
   }else{
    Serial.println("Tulis Interval Gagal!");
    Serial.println("");
i think the arduino have the permanently code, because when i upload this sketch and change this value, the program not removed and the value has change.
Code: [Select]
can you explain? and tell me how to make the permanently code?
sterretje
There is no need to cast a character to an integer before storing it in EEPROM. Further an integer is two bytes and EEPROM.write only writes one byte.
The preferred approach probably is something like
Code: [Select]
char  strDeviceID[10] = "HGT07"; // minimum length should be 6
char charBuf[10];
  EEPROM.put(0, strDeviceID);
  EEPROM.get(0, charBuf);
  if(strcmp(strDeviceID, charBuf) != 0)
    // not a match
    // match
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
