Topic: Arduino mega as joystick for pc (Read 599 times) previous topic - next topic
KarlaSvalina
Hi. I want to make big arduino gamepad for pc with a lot of joysticks and buttons. I made mini controller with arduino leonardo and joystick library and it worked and now I want to make bigger controller with arduino mega but I don't know how to make arduino mega as gamepad in controlpanel on windows 10. I bought arduino mega and mega mini. Please help me because I am new in arduino. Thank you. :)  :)
m_k_akash
thanks to Alan Chatham for creating this wonderful Unojoy library which could turn arduino into a potentially good joypad. Here you will find the support for the arduino mega also
thanks, Akash
You asked me and I am here
KarlaSvalina
m_k_akash
your welcome and all the best for your project
DrAzzy
Do note that that only works on offical mega2560 and the faithful clones with a 16u2 as serial adapter. The ones with a single-function serial adapter chip (like the countless clones with CH340G serial adapters - though clones with 16u2 are available) - those can't be reprogrammed.
ATTinyCore and megaTinyCore for all ATtiny, DxCore for DA/DB-series! github.com/SpenceKonde
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
sterretje
#5
Jul 07, 2020, 09:07 am Last Edit: Jul 07, 2020, 09:07 am by sterretje
You can always connect your Leonardo to the Mega via eg. a serial port and let the Leonardo do the hard work ;)
The Mega has 3 additional serial ports (Serial1, Serial2, Serial3) and the Leonardo hase one (additional) serial port (Serial1).
Using a Due instead of a Mega could also be (rather have been) an option (if I'm not mistaken).
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
