Topic: UNO R3 card maintenance (Read 1 time) previous topic - next topic
tmkane
Do folks clean pin-holes (breadboards) and connection ports on the UNO-R3 card?  I find inadvertent ("HIGH"  ("1") values with no action on the board such clicking a push-button or connecting jumper from pin hole to connection port.
Tom Kane / Canada
(deleted)
#1
Jul 09, 2020, 05:20 am Last Edit: Jul 09, 2020, 05:21 am by smarts-jb
(deleted)
(deleted)
#2
Jul 09, 2020, 05:34 am Last Edit: Jul 09, 2020, 05:57 am by smarts-jb
(deleted)
pert
edit: I should say the 3 ways with Arduino. I believe there are some devices with internal pulldowns
Although it was never documented in the Arduino Language Reference, both the Arduino SAMD Boards and Arduino Nano 33 BLE's pins can be set to an INPUT_PULLDOWN mode using pinMode().
Robin2
Never. Not even sure how I could do that. The sliding action of inserting and removing pins should keep the contacts clean.
I do keep my Arduinos away from chocolate cake.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
tmkane
To ROBIN2  Good idea (no chocolate cake)  Fortunately (I guess) I am diabetic, so the chocolate cake danger is not a threat to my UNO R3.
tmkane
To all:
Thanks for the PULLDOWN suggestion.  However, I am already using that practice;  I learned it from another forum.  Adding that feature (the actual resistor and the MODE) did not change the issue.
My next test will be disconnecting the wire from the Pin to see if that helps.  If it does I have to suspect that the pin "socket" is damaged (hence, my thought about cleaning the connectin holes)..
I did have one odd occurrence with a different project;  A jumper wire had excessive resistance (total about 3 ohms).  WEIRD.  After checking code and wiring I just guessed at the possible of a bad jumper.  Replacing the jumper cured THAT problem.  However, measuring resistance on my jumpers in this project did NOT show any excessive resistance;  replacing jumpers did not correct the problem.
ballscrewbob
Breadboards are prone to noise that could also cause those types of issue.
Along with wire jumpers not connected to anything, high humidity related static, extreme cold based static (yes that's a thing), badly routed wiring especially where higher than board level voltages are concerned.
It is also one of the reasons we often ask for pictures.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
tmkane
"My next test will be disconnecting the wire from the Pin to see if that helps.  If it does I have to suspect that the pin "socket" is damaged (hence, my thought about cleaning the connectin holes).."
Removing the write from the pin did not help.  I also tried rebuilding the hardware on a new UNO R3;  the same problem occurred!
BUT, I "tore down" the board and UNO wiring and re-built it.  I also stripped down the sketch;  thus far, the problem has not re-occurred!.  SO, this might be solved.  More to come after I  add more of the steps I want in a now stripped-down" sketch.
tmkane
Well, I tried to chose this "general discussion" forum, obviously misunderstanding the term "general."  Please consider this item closed through user incompetence.
TMKane
ballscrewbob
@tmkane
Simply EDIT your first post and add (SOLVED) to the end of the subject.
That is all you need to do.
