hello guys,
i am making bio metric door lock for my home. i am using fingerprint(adafruit R307) sensor and sg90 servo moto.
WHAT I WANT TO DO- when i put my finger to sensor, motor should go to 0 to 90 degree and again i put my same finger to sensor it should go to 90 to 0 degree.
PROBLEM- myservo motor work like sweep and some time it stop at 90 degree.
the problem might be in your code
i am using this code.
{ {do{myservo.write(20);
if(pos=0)
break;}
while(FINGERPRINT_OK);
Serial.println( myservo.read());}
{ {do{myservo.write(0);
if(pos=20)
break;}
The WHOLE sketch may be better but before you post it please take a little time with the two links below.
Could you take a few moments to Learn How To Use The Forum .
Other general help and troubleshooting advice can be found here.
I found this link:
there is also a video there with some instructions.
Also there are some examples after you install the library.
I also found examples on GitHub:
master/examples/fingerprint
Arduino library for interfacing to the fingerprint sensor in the Adafruit shop - Adafruit-Fingerprint-Sensor-Library/examples/fingerprint at master · adafruit/Adafruit-Fingerprint-Sensor-Library
I've never worked with the sensor, but I would start from there.
Hope it helps.
@vishwam_17
I warned you about duplicate posts Please take the next 7 days to read the links I provided earlier !
