Hello I have copy/pasted the sample code from the documentation and even by delaying 3mn between 2 messages I always have a sending error. I can send again by rebooting the board.
Must be something obvious...
Thanks for your help
#include <MKRWAN.h>
LoRaModem modem;
// Uncomment if using the Murata chip as a module
// LoRaModem modem(Serial1);
const int PIN_SEUIL = 2;
const int PIN_VALEUR = A1;
static unsigned long time = 0;
const unsigned long SAMPLE_PERIOD = 30000;
const unsigned long SENDING_PERIOD = 180000;
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
String appEui = SECRET_APP_EUI;
String appKey = SECRET_APP_KEY;
pinMode(PIN_SEUIL, INPUT); // sets the digital pin PIN_SEUIL as input
while (!Serial);
// change this to your regional band (eg. US915, AS923, ...)
if (!modem.begin(EU868)) {
Serial.println("Failed to start module");
while (1) {}
Serial.print("Your module version is: ");
Serial.println(modem.version());
Serial.print("Your device EUI is: ");
Serial.println(modem.deviceEUI());
int connected = modem.joinOTAA(appEui, appKey);
if (!connected) {
Serial.println("Something went wrong; are you indoor? Move near a window and retry");
while (1) {}
// Set poll interval to 60 secs.
modem.minPollInterval(60);
// NOTE: independently by this setting the modem will
// not allow to send more than one message every 2 minutes,
// this is enforced by firmware and can not be changed.
int humidite = 0;
int seuil = 0;
char buf[10];
// Lecture du PIN Analogique
humidite = analogRead(PIN_VALEUR);
Serial.print("Lecture Analogique = ");
Serial.println(humidite); // La valeur analogique brute
sprintf(buf, "%04d", humidite);
Serial.print("time ");
Serial.println(time);
if (time == 0 || millis() - time > SENDING_PERIOD)
int err;
time = millis();
modem.beginPacket();
modem.write(buf, 4);
err = modem.endPacket(true);
if (err > 0) {
Serial.println("Message sent correctly!");
Serial.println("Error sending message
Serial.println("(you may send a limited amount of messages per minute, depending on the signal strength");
Serial.println("it may vary from 1 message every couple of seconds to 1 message every minute)");
delay(SAMPLE_PERIOD);
