Arduino Forum
Using Arduino
Motors, Mechanics, Power and CNC
help with mosfet with brushless motor controller
Print
Pages:
[1]
Topic: help with mosfet with brushless motor controller
(Read 429 times)
previous topic
next topic
jonisonvespa
Sr. Member
[add]
Jack of all trades master of none (Note, Im not very well if my post dont make sense please be gently)
Jul 13, 2020, 12:14 pm
Last Edit
: Jul 13, 2020, 03:28 pm by jonisonvespa
hello
i have a brushless motor controller which i would like to hack ie make it switch higher currents
im thinking of using the same mosfet and in effect doubling them currently there is just 1 per pole im thinking of adding another same mosfet in parallel would this work can think of any reason why it wont?
thnks
This is it
https://www.onsemi.com/pub/Collateral/NTMFS5C628NL-D.PDF
MarkT
Brattain Member
[add]
Arduino rocks
Re: help with mosfet with brushless motor controller
#1
Jul 13, 2020, 12:50 pm
There's something really important you've neglected to tell us...
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
jonisonvespa
Sr. Member
[add]
#2
Jul 13, 2020, 02:39 pm
Last Edit
: Jul 13, 2020, 02:42 pm by jonisonvespa
The mosphet Im using is the same as is on the original same voltage just want to increase current Capability not sure if it has a gate driver will check
ballscrewbob
Global Moderator
? < This is a question. Try to answer
Shannon Member
[add]
#3
Jul 13, 2020, 03:05 pm
PDF files are not the best for use in the forum.
Actual links, pictures, text are much preferred.
Could you take a few moments to
Learn How To Use The Forum
Other general
help and troubleshooting advice can be found here.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
jonisonvespa
Sr. Member
[add]
#4
Jul 14, 2020, 03:31 pm
Last Edit
: Jul 14, 2020, 03:31 pm by jonisonvespa
No the mosfets do not have a driver, it gets signal from processor
jonisonvespa
Sr. Member
[add]
#5
Jul 15, 2020, 02:03 pm
Can anyone help please?
ballscrewbob
Global Moderator
Shannon Member
[add]
#6
Jul 17, 2020, 03:05 pm
Schematics and details for the current unit ?
Present MOSFET that is in there ?
Actual application you want to upgrade for ?
It is easy to stick a jet engine in a Mini but without context you would be on your own.
Print
Pages:
[1]
Loading...
