I'm currently working on "Connecting MATLAB to Arduino" in section 2.2 of Chapter 2. I have already mounted the MKR1000 on top of the MKR Motor Carrier in the correct orientation, the LiPo battery is connected with the black wire going to ground, and I have my motor M+ wire connected to the M3- connection on the board and the M- wire connected to the M3+ connection on the board. When I plug in the USB cable into the MKR1000, with the motor carrier switch set to off, the orange LED directly next to the green LED beside the on/off switch flashes once. Then, when I switch the on/off switch to on, the green LED that should light up does not. I'm also unable to get the motor running even after following the code instructions. I'm not getting any errors, it's simply just not running in response to the code. I've attached two photos below of the orange LED and the lack of the green LED.
I also checked the voltages using the four pins on the end of the board. VIN read as 12.5, and the 3.3 volts is correct, but there is no reading on the 5 volt pin. I tried with the on/off switch in both positions. Is this normal? I've attached pictures of each below as well.
Any help would be greatly appreciated!
