Topic: [Need Assistance] Can't make communication between two NRF24L01+PA+LNA modules (Read 204 times) previous topic - next topic
atsvetanov
I tried a few tutorials, but I didn't manage to do anything.
My setup is:
1x Uno
1x Nano
2x NRF24L01+PA+LNA
2x nrf24l01 adapter modules
1x USB HUB for the upload and reading serial outputs on both COMS.
Wiring on both is the same:
CE -> D9
CSV -> D8
SCK -> D12
MO -> D11
M1 -> D10
VCC -> 5V
GND -> GND
Code used:
For Transmitter (Nano)
//Include Libraries
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
//create an RF24 object
RF24 radio(9, 8);  // CE, CSN
//address through which two modules communicate.
const byte address[6] = "00001";
  radio.begin();
  //set the address
  radio.openWritingPipe(address);
  //Set module as transmitter
  radio.stopListening();
  //Send message to receiver
  const char text[] = "Hello World";
  radio.write(&text, sizeof(text));
For Receiver (Uno)
//Include Libraries
#include <SPI.h>
#include <RF24.h>
  while (!Serial);
  radio.begin();
  //set the address
  radio.openReadingPipe(0, address);
  //Set module as receiver
  radio.startListening();
  //Read the data if available in buffer
  if (radio.available())
    char text[32] = {0};
    radio.read(&text, sizeof(text));
    Serial.println(text);
Both uploads are OK, but I don't get anything on the receiver COM output.
My aim is for the complete the first step: one module to send a message and the other one to receive it.
I'm still learning basics, so I though, I should ask the experts for help, thank you in advance.
Robin2
Have a look at this Simple nRF24L01+ Tutorial.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
There is also a connection test program to check that the Arduino can talk to the nRF24 it is connected to.
A common problem with nRF24 modules is insufficient 3.3v current from the Arduino 3.3v pin. This seems to be a particular problem with the nano. The high-power nRF24s (with the external antenna) will definitely need an external power supply. At least for testing try powering the nRF24 with a pair of AA alkaline cells (3v) with the battery GND connected to the Arduino GND.
If you are using the high-power nRF24s (with the external antenna) make sure there is sufficient distance between the two nRF24s so that the signal does not overwhelm the receiver - try 3 metres separation. If you are new to nRF24s it may be better to start with a pair of low power modules with the pcb antenna.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
atsvetanov
Hey, I had a lot of work and I could not retry testing, but I'm up for some new results.
I tried new wiring from the thread given above, plus new code, but nothing successful.
This time my setup is:
2x Nano
2x NRF24L01+PA+LNA
My wiring is:
CE -> D9
CSN -> D10
SCK -> D13
MO -> D11
M1 -> D12
VCC -> 5V
GND -> GND
I tried the connection code, here is the output:
Same result on both pairs:
13:57:11.366 -> CheckConnection Starting
13:57:11.366 ->
13:57:11.366 -> FIRST WITH THE DEFAULT ADDRESSES after power on
13:57:11.434 ->   Note that RF24 does NOT reset when Arduino resets - only when power is removed
13:57:11.504 ->   If the numbers are mostly 0x00 or 0xff it means that the Arduino is not
13:57:11.606 ->      communicating with the nRF24
13:57:11.640 ->
13:57:11.640 -> STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
13:57:11.707 -> RX_ADDR_P0-1 = 0xe7e7e7e7e7 0x4141417852
13:57:11.741 -> RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
13:57:11.775 -> TX_ADDR = 0xe7e7e7e7e7
13:57:11.809 -> RX_PW_P0-6 = 0x00 0x20 0x00 0x00 0x00 0x00
13:57:11.877 -> EN_AA = 0x3f
13:57:11.877 -> EN_RXADDR = 0x03
13:57:11.912 -> RF_CH = 0x4c
13:57:11.912 -> RF_SETUP = 0x07
13:57:11.946 -> CONFIG = 0x0e
13:57:11.946 -> DYNPD/FEATURE = 0x00 0x00
13:57:11.981 -> Data Rate = 1MBPS
13:57:12.015 -> Model = nRF24L01+
13:57:12.015 -> CRC Length = 16 bits
13:57:12.050 -> PA Power = PA_MAX
13:57:12.085 ->
13:57:12.085 ->
13:57:12.085 -> AND NOW WITH ADDRESS AAAxR  0x41 41 41 78 52   ON P1
13:57:12.153 ->  and 250KBPS data rate
13:57:12.153 ->
13:57:12.153 -> STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
13:57:12.220 -> RX_ADDR_P0-1 = 0xe7e7e7e7e7 0x4141417852
13:57:12.289 -> RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
13:57:12.323 -> TX_ADDR = 0xe7e7e7e7e7
13:57:12.357 -> RX_PW_P0-6 = 0x00 0x20 0x00 0x00 0x00 0x00
13:57:12.392 -> EN_AA = 0x3f
13:57:12.392 -> EN_RXADDR = 0x03
13:57:12.392 -> RF_CH = 0x4c
13:57:12.427 -> RF_SETUP = 0x27
13:57:12.427 -> CONFIG = 0x0e
13:57:12.461 -> DYNPD/FEATURE = 0x00 0x00
13:57:12.495 -> Data Rate = 250KBPS
13:57:12.495 -> Model = nRF24L01+
13:57:12.530 -> CRC Length = 16 bits
13:57:12.564 -> PA Power = PA_MAX
13:57:12.564 ->
13:57:12.564 ->
BTW.
They are separated from each other about 20 cm.
I've plugged them both in one usb hub, so I can read both serial monitor.
Is that a problem?
Robin2
BTW.
Is that a problem?
Your connection test shows that communication is working properly.
Having two Arduinos with nRF24s connected to the same PC is not a problem.
It may be a problem having the two high-power nRF24s so close together - but I don't have any personal experience with them. My projects are all short-range projects with the low-power nRF24s with the PCB antennas.
...R
atsvetanov
Actually I moved a bit the antennas and it started working. Lol.
Overall, I used the first "simple tx & rx" code from your thread.
Back in rails, thanks for the support.
Robin2
I am curious to know how far you needed to separate the antennas to get the system working.
...R
