There was a recent topic on AvrFreaks. I wrote this sketch to write 50 toggles i.e. 100 edges. And measure the start and finish time with a Logic Analyser.
The interesting result is that Due digitalWrite() is appalling.
M0, M3 are not that impressive.
M4 gives very fast result.
In practice many Arduino apps know the wiring at compile-time. So can use the appropriate register writes.
If you have to determine the GPIO at run-time it is well worth writing a mask to the port address.
// F072 @ 48MHz F103 @ 64MHz L476 @ 80MHz F446 @ 180MHz SAM3X @ 84MHz SAMD21 @ 48MHz UNO @ 16MHz
//digitalWrite: 98.75us 47 101.6us 65 41.33us 33 18.5us 33cycle 207.2us 174 154.8us 74 356.5us 57
//PortAddress: 14.83 7 17.29 11 7.67 6 3.96 7 13.17 11 25.29 12 31.92 5
//ReadModifyWrite: 10.58 5 14.21 9 7.67 6 2.83 5 10.79 9 20.46 10 12.63 2
//WriteOnly: 4.33 2 3.29 2 1.33 1 0.58 1 2.38 2 8.96 4 12.63 2
#define TGL { TGL_RMW; }
#if 0
#elif defined(ARDUINO_SAM_DUE)
#define P8 PIOC
#define B8 22
#define P9 PIOC
#define B9 21
#define PIN_HIGH(port, pin) (port)-> PIO_SODR = (1<<(pin))
#define PIN_LOW(port, pin) (port)-> PIO_CODR = (1<<((pin)))
#define PIN_HIGHX(port, pin) (port)-> PIO_ODSR |= (1<<(pin))
#define PIN_LOWX(port, pin) (port)-> PIO_ODSR &= ~(1<<((pin)))
#elif defined(ARDUINO_ARCH_SAMD)
#define P8 REG_PORT_OUT0
#define B8 6
#define P9 REG_PORT_OUT0
#define B9 7
#define PIN_HIGH(port, pin) REG_PORT_OUTSET0 = (1<<(pin))
#define PIN_LOW(port, pin) REG_PORT_OUTCLR0 = (1<<((pin)))
#define PIN_HIGHX(port, pin) (port) |= (1<<(pin))
#define PIN_LOWX(port, pin) (port) &= ~(1<<((pin)))
#define P8 PORT_IOBUS->Group[0]
#define B8 6
#define P9 PORT_IOBUS->Group[0]
#define B9 7
#define PIN_HIGH(port, pin) (port).OUTSET.reg = (1<<(pin))
#define PIN_LOW(port, pin) (port).OUTCLR.reg = (1<<((pin)))
#define PIN_HIGHX(port, pin) (port).OUT.reg |= (1<<(pin))
#define PIN_LOWX(port, pin) (port).OUT.reg &= ~(1<<((pin)))
#elif defined(ARDUINO_ARCH_STM32)
#define P8 GPIOA
#define B8 7
#define P9 GPIOC
#define B9 7
#define PIN_HIGH(port, pin) (port)-> BSRR = (1<<(pin))
//#define PIN_LOW(port, pin) (port)-> BSRR = (1<<((pin)+16))
#define PIN_LOW(port, pin) (port)-> BRR = (1<<(pin))
#define PIN_HIGHX(port, pin) (port)-> ODR |= (1<<(pin))
#define PIN_LOWX(port, pin) (port)-> ODR &= ~(1<<((pin)))
#elif defined(ARDUINO_AVR_UNO)
#define P8 PORTB
#define B8 0
#define P9 PORTB
#define B9 1
#define PIN_HIGH(port, pin) (port) |= (1<<(pin))
#define PIN_LOW(port, pin) (port) &= ~(1<<(pin))
#define PIN_LOWX(port, pin) (port) &= ~(1<<(pin))
#endif
#define TGL_ARD { digitalWrite(8, HIGH); digitalWrite(8, LOW); }
//#define TGL_ADS { *d8Port |= d8PinSet; *d8Port &= ~d8PinSet; }
#define TGL_ADS { *d8Port |= d8PinSet; *d8Port &= d8PinClr; }
#define TGL_RMW { PIN_HIGHX(P8, B8); PIN_LOWX(P8, B8); }
#define TGL_WO { PIN_HIGH(P8, B8); PIN_LOW(P8, B8); }
#define TGL2 { TGL; TGL; }
#define TGL4 { TGL2; TGL2; }
#define TGL8 { TGL4; TGL4; }
#define TGL16 { TGL8; TGL8; }
#define TGL32 { TGL16; TGL16; }
#define TGL50 { TGL32; TGL16; TGL2; }
#if defined(__AVR__)
volatile uint8_t *d8Port;
uint8_t d8PinSet, d8PinClr;
#else
volatile uint32_t *d8Port;
uint32_t d8PinSet, d8PinClr;
#endif
Serial.print("toggle GPIO with OUTSET @ F_CPU = ");
Serial.print(F_CPU / 1000000);
Serial.println("MHz");
pinMode(13, OUTPUT);
pinMode(8, OUTPUT); //toggle signal
d8Port = portOutputRegister(digitalPinToPort(8));
d8PinSet = digitalPinToBitMask(8);
d8PinClr = ~d8PinSet;
pinMode(9, OUTPUT); //start, end signal
PIN_HIGH(P9, B9); //digital#9 PC21
TGL50; //100 edges digital#8 PA7
PIN_LOW(P9, B9);
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
David.
