Topic: Reverse a pwm signal to negative ? (Read 645 times) previous topic - next topic
Gadgeroonie
Hi guys,
I have a signal to drive a servo motor
The signal is a pwm and a direction pin (0 or 3.3v)
The servo driver I have is not compatible and requires a negative voltage to turn counter clockwise and a positive voltage to turn clock wise
If there a way to flip the voltage to negative when the direction pin is enabled ?
Perhaps I could use a simple h bridge and use that to flip the signal ?
MarkT
JCA34F
Arduino cannot produce negative voltages, post a link to that controller.
Gadgeroonie
The servo driver is a d200s
Uses the same manual as the d100s
https://www.manualslib.com/manual/1640073/Dvs-Ds100s-Series.html
Gadgeroonie
It appears it works with negative voltages when in torque mode
Paul_KD7HB
The schematic shows all input signals are opt-isolated, you statement makes no sense. Are you sure you are using what you linked to?
Paul
Gadgeroonie
Paul
Er yes
4 inputs are optoisolated the rest are not
Regardless, i am asking how to reverse a signal voltage
Do u have any suggestions ?
Paul_KD7HB
Er yes
I see the following inputs:
1. servo enable
2. Pulse signal
3. Direction signal
No fourth input on the document.
But to answer your question about reversing a signal voltage, a single transistor will invert the digital signal.
Paul
AJLElectronics
Ignoring all the other sensible advice you have been given, a simple inverter will turn a digital signal "upside down".
The other piece of advice I can give you is to check your keyboard, as the Y and O keys appear to be intermittent.
Wawa
Didn't read the document, but an opto could be normally off when connected between pin and ground, and normally on (inverted) when connected between pin and VCC.
Leo..
MarkT
Hi guys,
Well that's not the case is it - the position mode wiring diagram on page 4 clearly shows a standard
step/direction opto-isolated interface....
TomGeorge
#11
Aug 03, 2020, 04:38 am Last Edit: Aug 03, 2020, 04:40 am by TomGeorge
Have you tried a connection where the direction terminals are either connected to 5V or left open.
-5V is not the case, it is a simple logic HIGH/LOW to give you the two directions.
The terminals are polarised to make sure you activate the opto.
The wires are shown zig-zagged because they represent twist pairs.
It will be interesting to see if 3.3V will be enough.
So forget about -5V needed.
Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
Gadgeroonie
The diagram in the manual is for position mode
Torque mode uses different pins
Pin 5 is for the torque voltage
What i want to do is flip a 'analogue' voltage to negative
Ie 0.15 volts becomes -0.15 volts when the direction pin is enabled
AJLElectronics
Except that the concept of 0.15V is nonsense in this case. PWM is a digital signal. It stands for Pulse Width Modulation. It moves between logic 0 and logic 1 only.
Gadgeroonie
Except that isnt the case
The voltage is cleaned from a pwm to a smooth analogue voltage using a DAC
