So, i'm doing a switcher with an arduino DUE and i'm using 18 buttons. I can use INPUT_PULLUP, without a external resistor, for all pins or i continue using the pull down method? Please, someone can answer me, what is better to use?
This is a duplicate post
The other one has been moved to Project Guidance
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
