Topic: Transistor curve tracer with Arduino (Read 23103 times) previous topic - next topic
raurenest
I would like to share with you my last project, a transistor curve tracer using Arduino.
The idea is simple, i. e., to obtain the output I-V curves of a BJT by reading the voltage drops at the transistor when separate voltage sweeps at base and collector are applied (using a couple of DAC converters).
The project is conceived for educational purposes, so I do not expect to get very accurate curves as those provided by professional (and expensive) characterization systems. I intend just to be able to show to the students reasonable and realistic I-V curves corresponding to the discrete transistors they are using in lab work, getting those curves in the same lab for each specific transistor.
Up to now I've developed the Arduino sketch, that you may find below. The results are printed to the serial output, so you just need to copy&paste them to your favourite plotting software (Excel, SigmaPlot, etc.) to get the curves (just take into account that the data are repeated each time the main loop is run). The next step is to develop some Processing code to plot the results directly, getting the average values for several runs. In any case, all ideas about how to improve the project are welcome!
Here's the circuit (all connections are explained at the sketch)
And a couple of measuments I did with two different npn transistors
And finally, the Arduino sketch
Code: [Select]
This is the Arduino sketch for a transistor curve tracer.
Two 12-bit MCP4921 Digital-to-Analog (DAC) converters are used
to sweep the base and collector voltages and provide the output
characteristics. A 16-bit word needs to be written to the DAC
to set the analog voltage.
The circuit:
* Arduino pin 11 (MOSI) to pin 4 of both DACs
* Arduino pin 13 (CLK) to pin 3 of both DACs
* Arduino pin 10 to DAC1 pin 2
* Arduino pin 9 to DAC2 pin 2
* DACs pins 1 and 6 to 5V
* DACs pin 7 to GND
* DAC1 pin 8 (analog output) to base resistance RB
* DAC2 pin 8 (analog output) to collector resistance RC
* Transistor emitter to GND
* Transistor base to RB
* Transistor collector to RC
created 20 Aug 2011
by Raul Rengel
//Including the SPI library
#include <SPI.h>
//Slave Select (SS) pins for the base (10) and the collector (9)
// SSbase corresponds to DAC1, and SScollector to DAC2
const int SSBase = 10;
const int SSCollector = 9;
//Number of different values to be considered for base
//and collector voltages
const int sweepbase = 5;
const int sweepcollector = 50;
//Voltages to be measured (analog inputs)
// VCE - Collector-to-Emitter
const int VCE_Pin = 0;
// VCC - To output of DAC1 (pin 8)
const int VCC_Pin = 1;
// VBE - Base-to-Emitter
const int VBE_Pin = 2;
// VBB - To output of DAC2 (pin 8)
const int VBB_Pin = 3;
// Values read at the analog inputs of Arduino
int vceValue = 0;
int vccValue = 0;
int vbeValue = 0;
int vbbValue = 0;
//Step for the base and collector voltages;
int vstepbase = 4095/sweepbase;
int vstepcollector = 4095/sweepcollector;
//Values in volts
float vce = 0;
float vbb = 0;
float vcc = 0;
float vbe = 0;
//For the RC and RB values, change the values to your own
float Rcollector = 220.0; //Collector resistance (ohm)
float Rbase = 99900.0; //Base resistance (ohm)
float Icollector = 0; //Collector current
float Ibase = 0; // Collector base
  //Set SS pins as outputs
  pinMode(SSBase,OUTPUT);
  pinMode(SSCollector,OUTPUT);
  //Initialize the SPI Bus
  SPI.begin();
  //Transfer MSB first according to the MP4921 datasheet
  SPI.setBitOrder(MSBFIRST);
  //Set initial values for VBB and VCC (avoids some problems
  // with the first values to be read)
  dacTransfer(SSBase, 1);
  dacTransfer(SSCollector, 1);
  //Initialize serial
     for (int i=vstepbase; i <= 4095; i=i+vstepbase){
       for (int j=vstepcollector; j <= 4095; j=j+vstepcollector){
         dacTransfer(SSBase, i);
         dacTransfer(SSCollector, j);
         delay(100);
         readValues();
void dacTransfer(int slaveNumber, int value){
// 16-bit value is splitted into two bytes
// 4 most significant bits correspond to configuration of the DAC
// 12 least significant bits correspond to 12-bit data
  byte upperData = 0x30;  // Set the 4 configuration bits
  byte lowerData = 0x00;
  word dataWord; // The 16-bit word to be written
  dataWord = value;
  lowerData = lowByte(dataWord);
//transfer the 4 most significant bits of data to the upper byte
  upperData |= highByte(dataWord);
//Select the DAC
  digitalWrite(slaveNumber,LOW);
//Transfer the data
  SPI.transfer(upperData);
  SPI.transfer(lowerData);
//DAC is unselected
  digitalWrite(slaveNumber,HIGH);
void readValues() {
//Read the values at the analog inputs
  vbbValue = analogRead(VBB_Pin);
  vbeValue = analogRead(VBE_Pin);
  vccValue = analogRead(VCC_Pin);
  vceValue = analogRead(VCE_Pin);
//Convert to volts
  vce=(float)vceValue*5./1023.;
  vcc=(float)vccValue*5./1023.;
  vbb=(float)vbbValue*5./1023.;
  vbe=(float)vbeValue*5./1023.;
//Calculate collector and base currents
  Icollector=(vcc-vce)/Rcollector*1000.;
  Ibase=(vbb-vbe)/Rbase*1000000.;
//Print to serial output
// VCC, VBB, VBE, IC (mA), IB (uA)
  Serial.print(vcc);
  Serial.print("\t");
  Serial.print(vbb);
  Serial.print("\t");
  Serial.print(vbe);
  Serial.print("\t");
  Serial.print(vce);
  Serial.print("\t");
  Serial.print(Icollector);
  Serial.print("\t");
  Serial.print(Ibase);
  delay(10);
raurenest
Here's the Fritzing schematic, together with the Fritzing file attached.
Mathew99
Hello Raurenest  :) :) very amazed with this project. I was wondering if this will work for Pnp type transistor?
robtillaart
Very nice application.
1) you might zoom in in the 0..1V area as that might be the most interesting part  (are smaller steps possible?)
2) you might calculate the steepness between 0 .. 0.25V  and the one between 1-5V
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
BEREN
raurenest
I upload again the images (this time to the Arduino server to avoid problems).
raurenest
Sorry for the late replay. I think it would be problematic making this work with pnp transistors since you would need to apply negative base voltages. I would have to check with the DAC converter datasheet to see if this is possible just swapping the voltage source and the ground in that chip. The connections should be modified too to measure "negative" voltages.
Smaller steps are possible, yes. You just have to modify the sweepbase and sweepcollector values.
I haven't worked in this project in the last 2 or 3 years, but very probably this fall I will get back including a Processing interface to get live data. I'll let you know if I get back to it.
DROBNJAK
engrnuraz
hi, what type of dac that you use ?
pwillard
ThreeDMD
I'm a bit late to the show, but....
Would this setup be applicable for PN junctions?
I'm trying to design a similar setup but i'm looking to characterize LEDs with I-V curves.
Thanks in advance.
CrossRoads
For that, you need to control/measure two/three things in the simplest case:
apply voltage and measure current flow and LED brightness, without letting current get carried away as the voltage gets past the turn on point.
Or apply controlled current and measure resulting drop across the LED and the output brightness.
A DAC by itself won't do it. It can create a voltage,  but in general not very much current, and doesn't help at all in measuring LED brightness.
You can get programmable current sources, or create one with say a digitally controlled pot to adjust the output current.
CrossRoads
CrossRoads
Brightness measurement will be trickier, with receivers generally being dependent on the light frequency being measured.
ThreeDMD
Let's say I don't consider LED brightness and simply wish to look at I-V characteristics. I'm using SMT LEDs and dont require a lot of current. I'd like to simply attach a current sensor to the circuit, drive a ramped voltage and send back the currents from the sensor. To me, this seems feasible but I'm new to this. Perhaps I should take my questions to the project direction forums.
