Topic: Building a Tubidity meter (Read 2705 times) previous topic - next topic
Gustavohbo
Fascinating project. Can you give us some more detail about your experimental set-up? (eg a diagram or sketch?)
and also on the characteristics of the liquid you are using, as if its homogeneous this may not work?
I dont have a sketch of the actual prototype but I have of the old one with and LED and a LDR and the idea is the the same.
The only difference is that the actual has a infrared LED and a fototransistor.
OBS: I dont know how to attach an Image here so I atacched it at the end.
So the main objective is to measure if the water that Im receiving at home is always clear, for now I dont want to measure the turbidity in any scale (NTU, FTU, ...).
Im trying to make three equal sensors, so now I am analyzing their behavior with the same liquid and observating if they suffer the same variation from one sample to another. To make some tests with the sensor I am soiling (I dont know if it the correct word I used google translator for this one) the water with some dirt, coffee, milk.
So you should not expect a smooth signal. Perhaps you could do a statistical analysis of the variations you are seeing; in any case, the fact you ARE seeing variation is a good sign your messurement system is working.
In the future I will try to make some statics analizing.
Are you measuring transmitted or 90 degree scattered light? or both? and how are you collimating the light from the LED?
Currently I am using a 180º sensor but i think that i will make another prototype with the 90º and compare them.
I am not collimating the light, i didnt even think about it. I will make some research about it
Gustavohbo
Im using a 10k ohm pull up resistor what would happen with the reading if I reduce or increase it?
I want to know if there is some whey to make the sensor a bit more sensitive?
In the scale 0-1023 if there is nothing in the pipe (Air) the output is near 30 and if I put clear water the output goes to near 60.
Nazaar--
Quote
If you know about any more projects like this one, please send it to me
Thanks for your attention
These might be interesting to you:
A low cost continuous turbidity meter
and
An Affordable Open-Source Turbidimeter
Both use light-to-frequency sensors to measure the light from LEDs reflected off particles. The codes use the FreqCounter library.
Grumpy_Mike
I think I answered this before. Increasing it will make it more sensitive. As a transistor is a current operated device the voltage changes more across a higher value resistor than a lower one for any given current through it. Its called ohms law.
Gustavohbo
If I increase it a lot is there any chance of burning something? or something bad happpen?
Grumpy_Mike
Increasing the resistor only reduces the current. It is decreasing the resistor you have to be careful with. Don't go below about 300R.
johnerrington
#51
Aug 29, 2020, 08:15 am Last Edit: Aug 29, 2020, 08:19 am by johnerrington Reason: add image
Gustavo, this is the kind of diagram I had in mind:
the collimators are there to control the illumination angle and prevent light leaking from the source directly to the detector(s).
Ideally you want a narrow beam from the source, so choose an LED with a narrow beam angle.
I'm trying to help. If I find your question interesting I'll give you karma. If you find my input useful please give me karma (I need it)
Gustavohbo
#52
Nov 13, 2020, 08:40 pm Last Edit: Nov 16, 2020, 11:12 pm by Gustavohbo
You should aim to get the un - illuminated photo transistor to give very roughly a reading of 512, you can change this by altering the 10K value.
I stopped trying to measure the turbidity with these pair of infrared sensor, but now i need to make some new tests so I came back to this topic and read I all once again and I this part called my atention.
Why I should aim to measure 512 with an un-iliminated photo transistor?
And what you mean with a un-iluminated sensor?
Grumpy_Mike
Potential dividers work best when the two legs are about the same because any change in the sensor's value.
 Sensor and photo transistor are the same thing.
Gustavohbo
#54
Nov 15, 2020, 10:48 pm Last Edit: Nov 15, 2020, 10:54 pm by Gustavohbo
So i tried many resistors to reach  readings near 512 while the sensor is un-ilumininated but i think something is weird. I tried a wide range of resistor but still the reading are high.
1k      -> Un-iluminated Sensor = 995
2.2k   -> Un-iluminated Sensor = 994/995
3.3k   -> Un-iluminated Sensor = 994/995
10k    -> Un-iluminated Sensor = 992/993
22k    -> Un-iluminated Sensor = 990
100k  -> Un-iluminated Sensor = 983
1M    -> Un-iluminated Sensor = 824
My schematic:
aarg
#55
Nov 15, 2020, 10:56 pm Last Edit: Nov 15, 2020, 10:57 pm by aarg
I didn't read the entire thread, but it seems to me, your reference value of 512 should be when illuminated using a calibration solution - i.e. distilled water in the actual test fixture if you are measuring turbidity in water. Not when un-illuminated.
  ... with a transistor and a large sum of money to spend ...
Please don't PM me with technical questions. Post them in the forum.
MarkT
My schematic:
Clearly you need more like 3M3 or 4M7.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
johnerrington
Just adding some info at this point as I had to trawl through the whole thread to find it;
Quote
Gustav, you need to get the sensor part working first.  You also need to understand the behaviour of the devices you are using.
When un-illuminated a good (ideal) phototransistor should have infinite resistance -as no carriers are being generated at the junction.
Hence there is NO POINT in making measurements with it unlit.  Its no surprise your readings are high.
Really it would be better to
measure the current through the phototransistor, so connect it to +5 and your resistor to ground.
Try a 10k resistor.
Then point the LED at the phototransistor.
Check how the value changes with LED on & LED off.
Come back to us with ..
1: DETAIL what are the device part numbers?
2: REVISED SCHEMATIC  - so we can see what you have done
3: ANSWERS - what results did you get?
Meanwhile read this
https://johnloomis.org/ece445/topics/egginc/pt_char.html
TomGeorge
Can you please post a  picture of your phototransistor please?
You are  sure you are connected to the correct legs?
What is the part number off the phototransistor?
Thanks... Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
Grumpy_Mike
Quote
Is the sensor in the dark or is it exposed somehow to daylight?
