Haha good thought but I don't plan on using the sketch again if there ever was a 2.0.
I'll have a read up on state machine coding. I'm aware of utilising millis but i figured since there's nothing to do during delays, simple was better.
The box joints are done on a jig I made for my table saw. Another trick I was delighted to see work so well. Basically a 2 part sled, the front part you clamp your work to which has a pin the width of the saw kerf as a guide, which can slide between 'fingers' on the back piece (which is stuck in the table saw channels). You make the fingers by ripping a length of square stock the width of desired tenons, and cut it into 2xWidth lengths and stand every second one up.
I'll go fish it out if you want, a photo that might be easier hah.
