Topic: Daylight savings adjustment on DS1307 (Read 6120 times) previous topic - next topic
No1Daemon
Hi
I am new to the Arduino and I am trying to make some code to ato adjust for daylight savings.
Here is what I have written.
I am changing my time and date to 1:59am on the 25/9/2011 and trying to see if it changes forward from 2am to 3am and also setting it manually to 2:59am on the 1/4/2012 to see if it switches back again but with either scenario nothing happens so I guess I have got the code wrong.
The ds1307 seems to be reading and setting the time correctly. I have set up an lcd clock with it successfully and also just set and read to and from it via serial monitor so it is working correctly.
Could someone please tell me where I am going wrong.
Code: [Select]
#include <WProgram.h>
#include <Wire.h>
#include <DS1307.h> // written by  mattt on the Arduino forum and modified by D. Sjunnesson
byte DOW,MTH,DATE,DST,HR;
byte dows,mnths,dts,DST,hrs;
  RTC.stop();
  RTC.set(DS1307_SEC,20);        //set the seconds
  RTC.set(DS1307_MIN,59);     //set the minutes
  RTC.set(DS1307_HR,2);       //set the hours
  RTC.set(DS1307_DOW,1);       //set the day of the week
  RTC.set(DS1307_DATE,1);       //set the date
  RTC.set(DS1307_MTH,4);        //set the month
  RTC.set(DS1307_YR,12);         //set the year
  RTC.start();
// Daylight savings until 2020 for New Zealand
// Daylight savings changes forward from 2:00to 3:00on the last Sunday in September,
// and changes back from 3:00to 2:00 on the first Sunday of April
// so days between 25 and 31 in September and 1 to 6 in April is covered by this code
if (DOW == 1 && MTH == 4 || MTH == 9 && HR <1 && HR >4)                   // DST schedule for next ten years to october 2019 condition start in march or october
   DST = digitalRead(1060);                                                       // read Previous DST status,
    if (DOW == 1 && MTH == 4 && DATE <= 1 && DATE >=6 && HR == 2 && DST==0)   // time forward from 02:00 to 03:00 in march if DSt status ==0 else don't change time!
        RTC.set(DS1307_HR,3);       //set the  hours to 02:00                     // when status was ZERO (0) then change time from 02:00 to 03:00 hr
        digitalWrite(1060, 1);      // daylight saving flag                       // Write DST statusflag to ONE(1) to prevent multiple changes in hours, only for once in March
    if (DOW == 1 && MTH == 9 && DATE >= 25 && DATE <=31 && HR == 3 && DST==1)  // time backwards from 3:00 to 02:00 in october if DSt status ==1 else don't change time!
        RTC.set(DS1307_HR,2);       //set the  hours to 03:00
        digitalWrite(1060, 0);      // daylight saving flag                       // Write DST statusflag to ZERO to prevent multiple changes in hours, only for once in October
  Serial.print(RTC.get(DS1307_HR,true)); //read the hour and also update all the values by pushing in true
  Serial.print(":");
  Serial.print(RTC.get(DS1307_MIN,false));//read minutes without update (false)
  Serial.print(":");
  Serial.print(RTC.get(DS1307_SEC,false));//read seconds
  Serial.print("      ");                 // some space for a more happy life
  Serial.print(RTC.get(DS1307_DATE,false));//read date
  Serial.print("/");
  Serial.print(RTC.get(DS1307_MTH,false));//read month
  Serial.print("/");
  Serial.print(RTC.get(DS1307_YR,false)); //read year
Thanks
jmknapp
#1
Aug 21, 2011, 01:32 pm Last Edit: Aug 21, 2011, 01:36 pm by jmknapp Reason: 1
I wonder about this:
Quote
Shouldn't that be:
Quote
DATE >= 1 && DATE <=6
...or something like that anyway. Hard to see how a number can be <= 1 and >= 6 at the same time.
Joe
No1Daemon
Very good point. I missed that. Thanks
