What did you use for a load?
If you have wired it correctly, using the correct pinout (post a close up, focused photo of your setup), and measured the voltage with an accurate multimeter, then you may be the proud owner of counterfeit chips.
Counterfeits are quite common on Amazon, Alibaba, Banggood, etc. With Amazon, you should be able to return them.
