Even just this:
#include <SPI.h>
#include <ESP8266WiFi.h>
//test pattern: "█░"
#define ROW_CNT 7
#define BYTE_CNT 3
uint8_t FRAME_BYTES_DEFAULT[] = {254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 224, 254, 15, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 240, 127, 7, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 248, 63, 131, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193, 252, 31, 193};
uint8_t* frame_bytes = FRAME_BYTES_DEFAULT;
uint16_t frame_cnt = sizeof(FRAME_BYTES_DEFAULT) / (ROW_CNT*BYTE_CNT);
#define LED_COL_STATES(frame, row, byte) (frame_bytes[frame*(ROW_CNT*BYTE_CNT) + row*BYTE_CNT + byte])
#define P_TIMER D1
#define P_ENABLE D6
#define P_CLOCK D5
#define P_DATA D7
#define P_LATCH D2
#define ANL_OUT_MAX 1023 // for Wemos D1 mini
inline uint16_t f2anl(float val){return round(val * ANL_OUT_MAX);}
inline uint16_t anl_inv(uint16_t val){return ANL_OUT_MAX - val;}
void sleep(uint32_t ms){
uint32_t ts_start = micros();
while(micros()-ts_start < ms*1000){
delayMicroseconds(10);
yield();
uint8_t row = 0;
uint16_t frame = 0;
uint8_t frame_ctr = 0;
uint8_t frame_interval = 50;
uint16_t brightness = anl_inv(f2anl(0.5));
ICACHE_RAM_ATTR void refresh(){
// connections: rows>cols[0-7]>cols[8-15]>cols[16-23]
digitalWrite(P_ENABLE, HIGH);
SPI.transfer(LED_COL_STATES(frame, row, 0));
SPI.transfer(LED_COL_STATES(frame, row, 1));
SPI.transfer(LED_COL_STATES(frame, row, 2));
SPI.transfer(0b00000001 << row);
digitalWrite(P_LATCH, HIGH);
digitalWrite(P_LATCH, LOW);
analogWrite(P_ENABLE, brightness);
if(++row == ROW_CNT) row = 0;
if(++frame_ctr == frame_interval){
frame_ctr = 0;
if(++frame == frame_cnt) frame = 0;
void setup(){
pinMode(P_LATCH, OUTPUT); pinMode(P_ENABLE, OUTPUT);
pinMode(P_TIMER, INPUT);
SPI.begin();
SPI.beginTransaction(SPISettings(500000, MSBFIRST, SPI_MODE0)); // 500kHz; MSBFIRST -> start w/ bit 8; SPI_MODE0 -> CPOL=0, CPHA=0
SPI.endTransaction(); // does not revert settings applied in beginTransaction
analogWriteFreq(40000); //40kHz
WiFi.begin("id", "pass");
while(WiFi.status() != WL_CONNECTED) sleep(500);
attachInterrupt(digitalPinToInterrupt(P_TIMER), refresh, RISING);
void loop(){
is causing resets:
15:46:22.369 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
15:46:22.403 ->
15:46:22.403 -> load 0x4010f000, len 1384, room 16
15:46:22.403 -> tail 8
15:46:22.403 -> chksum 0x2d
15:46:22.403 -> csum 0x2d
15:46:22.403 -> v8b899c12
15:46:22.403 -> ~ld
15:47:09.263 ->
15:47:09.263 -> ets Jan 8 2013,rst cause:4, boot mode:(3,6)
15:47:09.263 ->
15:47:09.263 -> wdt reset
15:47:09.298 -> load 0x4010f000, len 1384, room 16
15:47:09.298 -> tail 8
15:47:09.298 -> chksum 0x2d
15:47:09.298 -> csum 0x2d
15:47:09.298 -> v8b899c12
15:47:09.298 -> ~ld
