Topic: Error compilando para la tarjeta Arduino Nano. (Read 395 times) previous topic - next topic
renzo0910
Buenas tardes, tengo el siguiente código, lo estoy compilando pero me manda el este error: C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_MonoOLED.h:30:10: fatal error: Adafruit_I2CDevice.h: No such file or directory #include <Adafruit_I2CDevice.h>
compilation terminated.
exit status 1
Usos el SO Windows 8 Enterprise.
Me han dicho que depende mucho del SO.
Alguien lo puede correr en Wundows 7 por favor y que me avise si le funcionó.
este es el codigo:
#include <SoftwareSerial.h>
#include "Arduino.h"
#include <Wire.h>//Include libraries: SoftwareSerial & Wire
SoftwareSerial ESP_BT(0,1); //Define PIN11 & PIN12 as RX and TX pins
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#include <EEPROM.h>
#ifndef PSTR
 #define PSTR // Make Arduino Due happy
#endif
#define PIN 5
// MATRIX DECLARATION:
// Parameter 1 = width of NeoPixel matrix
// Parameter 2 = height of matrix
// Parameter 3 = pin number (most are valid)
// Parameter 4 = matrix layout flags, add together as needed:
//   NEO_MATRIX_TOP, NEO_MATRIX_BOTTOM, NEO_MATRIX_LEFT, NEO_MATRIX_RIGHT:
//     Position of the FIRST LED in the matrix; pick two, e.g.
//     NEO_MATRIX_TOP + NEO_MATRIX_LEFT for the top-left corner.
//   NEO_MATRIX_ROWS, NEO_MATRIX_COLUMNS: LEDs are arranged in horizontal
//     rows or in vertical columns, respectively; pick one or the other.
//   NEO_MATRIX_PROGRESSIVE, NEO_MATRIX_ZIGZAG: all rows/columns proceed
//     in the same order, or alternate lines reverse direction; pick one.
//   See example below for these values in action.
// Parameter 5 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_GRBW    Pixels are wired for GRBW bitstream (RGB+W NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// Example for NeoPixel Shield.  In this application we'd like to use it
// as a 5x8 tall matrix, with the USB port positioned at the top of the
// Arduino.  When held that way, the first pixel is at the top right, and
// lines are arranged in columns, progressive order.  The shield uses
// 800 KHz (v2) pixels that expect GRB color data.
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(
  32,                                              //Select LEDs of each row (15 in my case)
  8,                                               //Select amount of rows (7 in my case)
  PIN,
  NEO_MATRIX_BOTTOM + NEO_MATRIX_RIGHT +           //Define first data pin (right bottom corner is my first pin)
  NEO_MATRIX_ROWS + NEO_MATRIX_ZIGZAG,             //Define the type of connection (in a zig zag connections and divided by rows not columns)
  NEO_RGB            + NEO_KHZ800);
  int Red=255,Green=0,Blue=0;
  String text="Easy Tech";
  String RGB;
  int pixelPerChar = 5,RGB_Completed=0;
  int Delay, Brightness;
const uint16_t colors[] = {matrix.Color(Green,Red,Blue)};
//  matrix.Color(255, 0, 0), matrix.Color(0, 255, 0), matrix.Color(0, 0, 255) };//matrix.Color(Red, Green, Blue),
  ESP_BT.begin(9600);
  EEPROM.begin();
 initdata();
 // Serial.println("Start");
  matrix.begin();
  matrix.setTextWrap(false);
  matrix.setBrightness(Brightness);
  matrix.setTextColor(colors[0]);
 //matrix.setTextColor(matrix.Color(Green,Red,Blue));
int x    = matrix.width();
int pass = 0;
  while(ESP_BT.available()){
    char ReadChar = (char)ESP_BT.read();
     Serial.println(ReadChar);
    // Right parentheses ) indicates complet of the string
    if(ReadChar == ')' ||ReadChar == '}' || ReadChar == ']'){
      if(ReadChar == ')' ){
      RGB_Completed = 1;
      if(ReadChar == '}'){
       RGB_Completed = 2;
      if(ReadChar == ']'){
       RGB_Completed = 3;
    else{
       RGB += ReadChar;
  if(RGB_Completed!=0){
      if(RGB_Completed==1){
             Light_RGB_LED();
             RGB_Completed=0;
      if (RGB_Completed==2){
          text=RGB;
           int _size = text.length();
            int i;
          for(i=0;i<_size;i++)
       EEPROM.write(50+i,text.charAt(i));
       Serial.println(text.charAt(i));
      EEPROM.write(50+_size,'\0');   //Add termination null character for String Data
           RGB_Completed=0;
           RGB="";
      if (RGB_Completed==3){
        int val=RGB.toInt();
        if(val>0 && val<=100){
          if(val==0){
            val=1;
          Delay=(100-val)*2.5;
          //scroll(Delay);
          EEPROM.write(0,Delay);
        else{
          val=val-100;
          matrix.setBrightness(val);
          EEPROM.write(5,val);
        RGB="";
        RGB_Completed=0;
   if(RGB_Completed==0){
  //.  Serial.println(RGB_Completed);
    scroll();
void scroll(){
  //Serial.println(text);
  int  maxDisplacement = text.length() * pixelPerChar + matrix.width();
  matrix.fillScreen(0);
  matrix.setCursor(x, 0);
  matrix.print(text);
  if(--x < -maxDisplacement) {
    x = matrix.width();
    if(++pass >= 1){ pass = 0;
   // matrix.setTextColor(colors[pass]);
    //  matrix.setTextColor(matrix.Color(Red,Green,Blue));
  matrix.show();
  delay(Delay);
void Light_RGB_LED(){
  int SP1 = RGB.indexOf('.');
  int SP2 = RGB.indexOf('.', SP1+1);
  int SP3 = RGB.indexOf('.', SP2+1);
  String R = RGB.substring(0, SP1);
  String G = RGB.substring(SP1+1, SP2);
  String B = RGB.substring(SP2+1, SP3);
  Red=R.toInt();Green=G.toInt();Blue=B.toInt();
// Serial.println(R);
  EEPROM.write(10,Red);EEPROM.write(15,Green);EEPROM.write(20,Blue);
 RGB="";
Function:
void initdata(){
     int Speed=EEPROM.read(0);
     if(Speed==NULL || Speed==0){
      Delay=100;
       else{
        Delay=Speed;
    int bright=  EEPROM.read(5);
     if(bright==NULL || bright==0){
      Brightness=40;
       else{
        Brightness=bright;
    int r=  EEPROM.read(10);
     if(r==NULL){
        Red=0;
       else{
        Red=r;
    int g=  EEPROM.read(15);
     if(g==NULL){
        Green=255;
       else{
        Green=g;
   int b=  EEPROM.read(20);
     if(b==NULL){
        Blue=0;
       else{
        Blue=b;
  char data[100]; //Max 100 Bytes
   int len=0;
    char k;
   String Text= "";
  k=EEPROM.read(50);
  while(k != '\0' && len<500)   //Read until null character
    k=EEPROM.read(50+len);
    data[len]=k;
    Text+=k;
    len++;
  data[len]='\0';
     if(Text==NULL){
        text="EASY TECH";
       else{
        text=Text;
Serial.println(Speed);
Serial.println(Brightness);
Serial.println(Red);
Serial.println(Green);
Serial.println(Blue);
De antemano gracias, por los que me puedan ayudar
surbyte
Moderador
Por favor edita tu post usando etiquetas de código.
Normas del foro
