I am getting this message using Arduino Web IDE. Please help how to solve this
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\MODHU BAGANI\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't set com-state for "\.\COM4"
avrdude done. Thank you.
An error occurred while uploading the sketch
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Ensure you have NOTHING connected to pins D0 & D1.
Also please read the posts at the top of this section as there are some web editor specific help and hints.
Thanks it worked after restarting the PC.
Now I am getting new message
avrdude: verifying ...
avrdude: 4540 bytes of flash verified
avrdude: safemode: lfuse reads as 0
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: safemode: Fuses OK (E:00, H:00, L:00)
create.txt (6.16 KB)
But Im trying to run stepper connected to board . Its not working.
