Topic: Problema visualización pantalla LCD Arduino UNO (Read 408 times) previous topic - next topic
lelar
Hola, soy nuevo en este mundo del Arduino y tengo un problema con la pantalla del LCD, creo que se debe a que pude haber quemado una patilla de los pines,no lo sé.
Se ve unos cuadrados de color blanco y las letras dentro, es apenas distinguible lo que dice (no pude adjuntar foto).
Aquí va el código:
//CONFIGURACION PINES Y LIBRERIA
#include <LiquidCrystal.h>
#define LED 4
#define BOTON 2
#define PIN1 7
#define PIN2 8
#define PIN3 9
#define PIN4 10
#define PIN5 11
#define PIN6 12
#define DELAYBOTON 300
//DEFINICION DE VARIABLES
LiquidCrystal lcd(PIN1,PIN2,PIN3,PIN4,PIN5,PIN6);
int cambio=0;
void setup(){
  pinMode(PIN1,OUTPUT);
  pinMode(PIN2,OUTPUT);
  pinMode(PIN3,OUTPUT);
  pinMode(PIN4,OUTPUT);
  pinMode(PIN5,OUTPUT);
  pinMode(PIN6,OUTPUT);
  pinMode(LED,OUTPUT);
  pinMode(BOTON,INPUT_PULLUP);
  digitalWrite(LED,LOW);
  lcd.begin(16,2);
  lcd.print("Estado LED");
  lcd.setCursor(0,1);
  lcd.print("Apagado");
void loop(){
  //COMPRUEBA SI PULSE BOTON
  if(digitalRead(BOTON)==LOW){
    if(cambio==0){
      lcd.clear();
      lcd.setCursor(0,1);
      lcd.print("PRENDIDO");
      cambio=1;
    }else{
      lcd.clear();
      lcd.print("Estado Led: ");
      lcd.setCursor(0,1);
      cambio=0;
    delay(DELAYBOTON);
  //Prendo o apago led
  if(cambio==1){
    digitalWrite(LED,HIGH);
  }else{
groundFungus
#1
Aug 29, 2020, 10:44 pm Last Edit: Aug 29, 2020, 10:46 pm by groundFungus
Translated:
Quote
Hello, I am new to this world of Arduino and I have a problem with the LCD screen, I think it is because I could have burned a pin of the pins, I do not know.
You can see some white squares and the letters inside, it is barely distinguishable what it says (I could not attach a photo).
Here is the code:
Adjust the contrast potentiometer.
You will save everyone's time if you read and follow the forum guidelines.  :)
https://forum.arduino.cc/index.php/topic,148850.0.html
and
https://forum.arduino.cc/index.php?topic=97455.0
lelar
groundFungus
Post a photo of your connections, please.
I tried your code with my Uno and a 16x2 LCD.  It displays:
Estado LED
Apagado
So the code for the LCD works.  Therefore there is a wiring problem.  Is the R/W pin (LCD pin 5) connected to ground?  It should be.  Disconnect the potentiometer from pin 3 of the LCD and connect a 1K resistor from LCD pin 3 to ground.  What do you see now?
and
surbyte
Moderador:
Por favor, lee las normas del foro, de todo el foro no solo este.
Si posteas en el foro en inglés usas inglés y si alguien posteas en el foro en Español lo hace en nuestro idioma.
Asi que abstenerse de usar inglés.
To people that writes in english:
Please don´t use that language to post answers in this forum.
Además edita tu post inicial usando etiquetas para código.
En este foro respetamos las normas una por una.
Normas del foro.
