Topic: max ampere for VIN pin (Read 29685 times) previous topic - next topic
fux
Aug 25, 2011, 06:25 pm Last Edit: Aug 25, 2011, 06:29 pm by fux Reason: 1
Hi there,
what is the maximum ampere the VIN pin of the Arduino UNO can handle when using an external power supply via the power jack.
Is there any limitation?
thanks,
Andreas
retrolefty
Hi there,
thanks,
Andreas
Yes, there is a series polarity protection diode wired between the external power connector + to the Vin pin, this is I believe a nominal 1 amp maximum forward current rated diode.
Lefty
MarkT
Also the on-board regulator can overheat if it dissipates too much power (it should just shutdown if this happens).  The heat in the regulator depends on the (Vin - 5)*current.  In general any high current 5V devices should not be powered from the Arduino 5V output via the regulator - they should have their own power supply arrangements.
Grumpy_Mike
The actual current available out of the on board regulator depends on the exact voltage you put in. This is because of power dissipation and heat sinking capacities. See here for some calculations:-
http://www.thebox.myzen.co.uk/Tutorial/Power_Examples.html
retrolefty
Yes, of course. However the original question was how much Vin current could the OP draw from the Vin pin to power external componets. So the on-board +5vdc regulator is really only related in that it too draws from the total external power current limit imposed by the series diode.
Lefty
Grumpy_Mike
Yes that is what he said, but was that what he meant?
To me it makes little sense asking exactly what he asked.
retrolefty
#7
Aug 26, 2011, 05:14 am Last Edit: Aug 26, 2011, 05:19 am by retrolefty Reason: 1
Why do you say that? If he using an external +12vdc power source plugged into the arduino external power plug and wants to then power some external devices that requires +12vdc, say a solenoid or relay using the +12vdc avalible at the Vin pin, then it's a very logical question to ask how much current can one safely draw from the Vin pin. The limit is the current rating of the external power source or one amp, whichever is less (minus whatever current the on-board regulator is drawing). No ?
Lefty
fux
Lefty you got it.
Your first reply answered my question.
Normally I power parts like a MOSFET plus solonoid with its own power supply and not through the VIN pin.
I was just curious what is the limitation of the VIN pin.
Thanks again.
Grumpy_Mike
Quote
Lefty you got it.
Well done.  :)
drone
It's worth noting that I have about a thousand devices in the field drawing from 1.25A to 2A @12V through the Arduino Vin pin (to a shield), and none of them have burned out any traces or melted any pins in the Arduino =)
The biggest concern I had originally, was the trace size from the dc plug to the Vin pin, which seems fairly small, and AFAIK the Arduino boards use 1oz pours.  (My shield uses 20 mil traces for the biggest consuming paths, and 2oz pours.)  However, this has not proven out to be an issue.  However, I still have some serious concerns in the long run, considering a lot of the female headers I see out there are rated @ 2A through each contact.  I don't know the specific P/N of the headers used in the Arduino, but I'd bet money on them being around the same.
!c
retrolefty
#11
Aug 26, 2011, 09:26 pm Last Edit: Aug 26, 2011, 09:28 pm by retrolefty Reason: 1
Quote
Well the issue (and limit) is the maximum continuous forward current rating of the series polarity protection diode wired between the external power connector and the Vin pin. This diode will pass all current supplied to the board and any current consumed off board via the Vin pin. Does anyone one know the actual diode part number used and it's max forward current rating? I have no doubt one can draw more then it's safe rating but it's not an accepted good engineering practice to do so. I always assumed it was a bog standard 1 amp diode?
Lefty
drone
You know, now I feel like an Idiot with a capital I.
No matter how many times I've looked at that schematic, I've blocked D1 out of my mind until this moment.
Now I'm nervous, hah. (Well, not really... But now I just have to know!)  I'm going to take a look when I get home and see if I can discern anything...
!c
drone
My duemilanove in front of me has a 4007 diode.  Meaning, 1A max continuous.
!c
retrolefty
!c
Yea, but I've had a 5 amp transistor blow up to protect a 2 amp fuse.  :D
