Topic: max ampere for VIN pin (Read 27888 times) previous topic - next topic
drone
Yea, but I've had a 5 amp transistor blow up to protect a 2 amp fuse.  :D
Yeah, pretty much every 4N007 has a 30A "spike" current, and "spikes" can be loosely defined, in my example, I'm doing lots of PWM, so those "spikes" are very short, but very often =)
!c
Gitternmaker
Just a thought - it's quite easy to solder a wire (or a 1-pin socket) to the back of the input jack on an Uno. That way, you can take off the input voltage before it goes through D1. I'm using that method to breadboard a multi-servo system. The servos are powered by a separate regulator, but it saves having two power supplies.
terryking228
#17
Feb 08, 2015, 03:08 am Last Edit: Feb 08, 2015, 03:36 am by terryking228
FYI The UNO uses a "M7" Diode.. 1A continuous.
See: http://www.kingtronics.com/pdf/M7-diode.pdf
See this and much more about Arduino power capabilities and limitations  HERE:
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
