Topic: Serial monitor shows squares (Read 181 times) previous topic - next topic
mamw
Sep 11, 2020, 04:33 pm Last Edit: Sep 11, 2020, 10:34 pm by Coding Badly
hi,
I have an arduino nano that connected to sim800l. the problem is that when i try to print data coming from gsm the serial monitor shows squares but when I write to serial monitor it show what i am typing.
my baud rate both are 9600 and in the serial monitor is the same. The code was working good but now it is not.
here is the code  I am using
Code: [Select]
#include <SoftwareSerial.h>
//Create software serial object to communicate with SIM800L
SoftwareSerial mySerial(2, 3); //SIM800L Tx & Rx is connected to Arduino #3 & #2
  //Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
  //Begin serial communication with Arduino and SIM800L
  mySerial.begin(9600);
  Serial.println("Initializing...");
  mySerial.println("AT"); //Once the handshake test is successful, it will back to OK
  updateSerial();
  mySerial.println("AT+CSQ"); //Signal quality test, value range is 0-31 , 31 is the best
  updateSerial();
  mySerial.println("AT+CCID"); //Read SIM information to confirm whether the SIM is plugged
  updateSerial();
  mySerial.println("AT+CREG?"); //Check whether it has registered in the network
  updateSerial();
 updateSerial();
void updateSerial()
  while (Serial.available())
    mySerial.write(Serial.readString());//Forward what Serial received to Software Serial Port
  while(mySerial.available())
    Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
I just copy it from https://lastminuteengineers.com/
ieee488
take a look at http://www.martyncurrey.com/hc-05-with-firmware-2-0-20100601/#AT-Command-Mode which is similar to what you are doing except for the different baud rate
GolamMostafa
#2
Sep 12, 2020, 01:59 pm Last Edit: Sep 12, 2020, 01:59 pm by GolamMostafa
Try the following line:
Code: [Select]
Serial.print(mySerial.read());//Forward what Software Serial received to Serial Port
Or
Code: [Select]
Serial.write((char)mySerial.read());//Forward what Software Serial received to Serial Port
mamw
thanks for your reply,
the first line shows 255255255255255255255...
the second shows squares
cattledog
Quote
What changed?
