Topic: Yun Rev2 USB port sketch-upload problem.  (Read 491 times) previous topic - next topic
hiddenl
When I upload a sketch via WiFi, it works ok, avrdude reports: avrdude: Device signature = 0x1e9587 (probably m32u4) and everything loads ok.  :smiley: The WiFi side works great I can access via SSH etc.
However, when I load over USB, its fails and avrdude reports: avrdude: Device signature = 0xff0d0d
avrdude: Expected signature for ATmega32U4 is 1E 95 87  :smiley-sad:
I can use the serial monitor on USB just fine, just not upload sketches. And I can use the sketch terminal to access the linux side of the yun.
Anyone know a fix? I cannot find anything on google or the forums... Complete log (verbose) for USB failed load:
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/snap/arduino/42/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/home/dlinano/snap/arduino/42/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
    Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
    Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: butterfly_recv(): programmer is not responding
################################################## | 100% 5.00s
         Double check chip, or use -F to override this check.
