Topic: ATMEGA328P U internal temperature ? (Read 363 times) previous topic - next topic
Nico_TheDecoder
I recently bought 2 pcs. Arduino UNO (clone model) with this type of IC (ATmega328P-U).
And have discovered that both clone models (ATmega328P-U), can not read out internal temperature sensor correctly.
I used this code:
Code: [Select]
// Internal Temperature Sensor
// Example sketch for ATmega328 types.
// https://playground.arduino.cc/Main/InternalTemperatureSensor/
// April 2012, Arduino 1.0
  Serial.println(F("Internal Temperature Sensor"));
  // Show the temperature in degrees Celsius.
  Serial.println(GetTemp(),1);
double GetTemp(void)
  unsigned int wADC;
  double t;
  // The internal temperature has to be used
  // with the internal reference of 1.1V.
  // Channel 8 can not be selected with
  // the analogRead function yet.
  // Set the internal reference and mux.
  ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));
  ADCSRA |= _BV(ADEN);  // enable the ADC
  delay(20);            // wait for voltages to become stable.
  ADCSRA |= _BV(ADSC);  // Start the ADC
  // Detect end-of-conversion
  while (bit_is_set(ADCSRA,ADSC));
  // Reading register "ADCW" takes care of how to read ADCL and ADCH.
  wADC = ADCW;
  // The offset of 324.31 could be wrong. It is just an indication.
  t = (wADC - 324.31 ) / 1.22;
  // The returned temperature is in degrees Celsius.
  return (t);
My output from ATmega328P-U (Temp in °C):
Code: [Select]
15:51:22.045 -> 9.6
15:51:23.063 -> 9.6
15:51:24.081 -> 9.6
15:51:25.096 -> 9.6
15:51:26.113 -> 8.8
15:51:27.133 -> 9.6
15:51:28.185 -> 9.6
15:51:29.173 -> 9.6
15:51:30.222 -> 10.4
15:51:31.240 -> 10.4
15:51:32.257 -> 10.4
15:51:33.277 -> 10.4
15:51:34.297 -> 11.2
15:51:35.316 -> 11.2
15:51:36.332 -> 11.2
15:51:37.354 -> 11.2
15:51:38.372 -> 11.2
15:51:39.391 -> 11.2
15:51:40.412 -> 11.2
15:51:41.430 -> 11.2
15:51:42.450 -> 11.2
15:51:43.468 -> 14.5
15:51:44.487 -> 18.6
15:51:45.508 -> 23.5
15:51:46.527 -> 24.3
15:51:47.546 -> 23.5
15:51:48.564 -> 22.7
15:51:49.584 -> 21.9
15:51:50.603 -> 21.1
15:51:51.655 -> 21.1
15:51:52.672 -> 19.4
15:51:53.692 -> 19.4
15:51:54.712 -> 18.6
15:51:55.730 -> 17.8
15:51:56.724 -> 17.8
15:51:57.775 -> 17.0
15:51:58.794 -> 17.0
15:51:59.812 -> 16.1
15:52:00.832 -> 16.1
15:52:01.851 -> 16.1
15:52:02.871 -> 16.1
15:52:03.897 -> 15.3
15:52:04.915 -> 15.3
15:52:05.934 -> 15.3
15:52:06.953 -> 15.3
15:52:07.971 -> 14.5
15:52:08.992 -> 14.5
15:52:10.010 -> 12.9
15:52:11.030 -> 12.9
15:52:12.048 -> 12.9
15:52:13.068 -> 12.0
15:52:14.088 -> 12.0
15:52:15.104 -> 12.0
15:52:16.124 -> 11.2
15:52:17.141 -> 11.2
15:52:18.162 -> 11.2
15:52:19.181 -> 10.4
15:52:20.201 -> 10.4
15:52:21.222 -> 10.4
15:52:22.240 -> 10.4
15:52:23.260 -> 10.4
15:52:24.280 -> 10.4
15:52:25.329 -> 10.4
15:52:26.349 -> 10.4
15:52:27.368 -> 9.6
15:52:28.386 -> 10.4
15:52:29.406 -> 9.6
15:52:30.424 -> 9.6
15:52:31.441 -> 9.6
15:52:32.460 -> 9.6
15:52:33.478 -> 9.6
15:52:34.498 -> 9.6
15:52:35.516 -> 9.6
15:52:36.535 -> 9.6
15:52:37.555 -> 9.6
15:52:38.576 -> 9.6
15:52:39.597 -> 9.6
15:52:40.615 -> 9.6
15:52:41.635 -> 8.8
15:52:42.651 -> 9.6
15:52:43.676 -> 9.6
15:52:44.694 -> 9.6
15:52:45.712 -> 9.6
15:52:46.733 -> 9.6
15:52:47.748 -> 9.6
15:52:48.766 -> 9.6
The temperature fluctuation is made by heating the IC with a lighter for a few seconds  :smiley-twist:
However, if I use ATmega328P-PU, then the reading of internal temperature sensor works perfectly.
It seems to me strange that ATmega328P-U, can not read out internal temperature sensor correctly.
Do others have this experience?
UKHeliBob
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
jremington
#2
Sep 17, 2020, 03:21 am Last Edit: Sep 17, 2020, 04:13 am by jremington
Needs calibration. The error spec is +/- 10 degrees C, I think.
srnet
You have not actually told us what you mean by an 'incorrect' or a 'perfect' reading.
However as already mentioned, the ATmega datasheet specifies an accuracy of +/- 10C.
No PMs please, they dont get answered.
