Topic: Arduino and Mosfet module (Read 358 times) previous topic - next topic
davax
Sep 14, 2020, 08:27 pm Last Edit: Sep 14, 2020, 08:29 pm by davax
Why is arduino running ? I did not send the signal to turn mosfet on
https://imgur.com/fcqf3uo
UKHeliBob
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
davax
#2
Sep 15, 2020, 08:32 am Last Edit: Sep 15, 2020, 08:38 am by davax
UKHeliBob
davax
? why is arduino on , and mosfet is off
UKHeliBob
Your circuit looks wrong
Shouldn't the battery go to VIN on the MOSFET module  and the V- and V+ terminals supply power when the signal pin is taken HIGH ?
It would help if you described what you are trying to do
davax
#6
Sep 15, 2020, 04:01 pm Last Edit: Sep 15, 2020, 04:02 pm by davax
So everything is turned off
I will add a button , which when i hold it will direct power the arduino from battery , until it turns the Mosfet ON
And after 2 minits i added in code , arduino turns the Mosfet OFF ,  and everything is off , so no power consuption ...
UKHeliBob
Quote
Please post a diagram of your complete circuit
Noting what I said in reply #5, are you sure that VIN and GND of the MOSFET module should be connected to VIN and GND on the Arduino ?
davax
#8
Sep 15, 2020, 05:44 pm Last Edit: Sep 15, 2020, 05:48 pm by davax
I connected it now like you said and same
When i connect the battery wires arduino is ON , but it need to be off right ? because there is no signal to turn it on
My only problem is why is arduino always ON ?
Mosfet is like relay right ?  When i give signal (power) to coil then it turns on
But here it is always on !
davax
Look , arduino works , and there is no input , to turn mosfet on
UKHeliBob
Take the Arduino out of the circuit until you know what you are doing.  The picture in reply #9 shows the battery connected between V+ and V-.  Why ?
davax
Only difference is , there is arduino  and no motor ,...
UKHeliBob
In the picture in reply #9 your battery is connected to V+ and V-
In the diagram in post #11 the power is connected to VIN and GND
Spot the difference
davax
I tried both cases , and same happens
Nvm , i will use relay,  with relay works normal..
thanks anyway :)
