Topic: HMC5883L magnetometer Proteus simulation ? (Read 212 times) previous topic - next topic
ahmed44
hi guys
i was trying to simulate the HMC5883L magnetometer sensor in Proteus and after a hard time finding it i was able to make it work , at least i think ,  because there is no change in the position of the sensor i get a reading of 0 , is there is a way to simulate its motion to get any reading ?
the code :
#include <Wire.h> //I2C Arduino Library
#include <LiquidCrystal.h>
LiquidCrystal lcd (4,5,6,7,8,9);
#define addr 0x0D //I2C Address for The HMC5883
lcd.begin(16,2);
  Wire.begin();
  Wire.beginTransmission(addr); //start talking
  Wire.write(0x0B); // Tell the HMC5883 to Continuously Measure
  Wire.write(0x01); // Set the Register
  Wire.endTransmission();
  Wire.write(0x09); // Tell the HMC5883 to Continuously Measure
  Wire.write(0x1D); // Set the Register
  int x, y, z; //triple axis data
  //Tell the HMC what regist to begin writing data into
  Wire.write(0x00); //start with register 3.
  //Read the data.. 2 bytes for each axis.. 6 total bytes
  Wire.requestFrom(addr, 6);
  if (6 <= Wire.available()) {
    x = Wire.read(); //MSB  x
    x |= Wire.read() << 8; //LSB  x
    z = Wire.read(); //MSB  z
    z |= Wire.read() << 8; //LSB z
    y = Wire.read(); //MSB y
    y |= Wire.read() << 8; //LSB y
  // Show Values
lcd.setCursor(0,0);
lcd.print(x);
lcd.setCursor(0,1);
 lcd.print(z);
groundFungus
You will save everyone's time if you read and follow the forum guidelines.  :)
https://forum.arduino.cc/index.php/topic,148850.0.html
DrDiettrich
If you simulate, a turn from max value decreases the value by the cosine function, eventually plus an offset. In each direction for 3D moves.
I wonder what else you expect from simulation? Simulation is based on a mathematical model, the same for all such  sensors. You only add arbitrary constants, not related to sensor behaviour unless you have a real sensor for parametrization.
ahmed44
so is there any thing i can do to check if i am getting the right readings from the sensor ? or magnetometers in general cannot be simulated in proteus ?
i didn't expect much from the simulation but i thought that it might have the ability to change position by a potentiometer or any thing (any mimicking technique) , like the lm35 in proteus it has a button to change the temperature .
DrDiettrich
The HMC5883L sensor includes its own controller. A simulation would need description of a 3D magnetic field and sensor orientation in 3 axes, as well as the settings of all parameters.
Magnetometers are influenced by local magnetic fields more than by earth magnetic field. If you don't trust a sensor, get some more and compare their outputs.
TomGeorge
Build it in the real world and find out.....
What do you want to do with the sensor?
Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
ahmed44
the thing is that i am engaged in something called a summer school for aerospace science and with my team we are supposed to build a space environmental monitor using various sensors including this HMC5883L , but our instructor don't want us to start building with real hardware unless we completed the simulation of all of these sensors in Proteus and made sure that it works?! , any ways
i revised my code a little bit and found that i was giving the wrong bus address for 12c , but after changing it to 0x1E it worked :
yet no mechanism for changing the values during simulation , but i guess i am satisfied with that result .
but i still have a question : what is the 17159 represent , is it the magnetic field strength in the x direction
in some unit ? assuming that the simulation knows what a magnetic field is
DrDiettrich
Can you choose a different project with a more realistic instructor? I bet that s/he cannot tell how to simulate a magnetometer in any software. Not being well grounded is not a reasonable base for aerospace science :-(
ahmed44
unfortunately we cannot change the project ,  i actually feel sorry for the other members of my team they don't have much experience with Arduino . but i guess with your help guys i think we might pull it off .
DrDiettrich
Did you already get an Arduino library for the magnetometer? If not look for a better supported sensor.
TomGeorge
#10
Sep 16, 2020, 11:53 pm Last Edit: Sep 16, 2020, 11:54 pm by TomGeorge
If you google
HMC5883L simulating in proteus
You may find what you are looking for.
Tom... :)
ahmed44
it seems that this sensor uses the I2C protocol so i just used the <wire.h> library and the address of the sensor from the datasheet , i don't think the instructor could change the sensor .
ahmed44
If you google
Tom... :)
i didn't find any thing related to this sensor with Proteus ! , have you found any ?!
TomGeorge
#13
Sep 17, 2020, 07:52 am Last Edit: Sep 17, 2020, 07:58 am by TomGeorge
You don't have to change the sensor to use the library for the 5883.
The library uses I2C.
Tom... :)
PS, Your instructor needs to get into the real world. Simulators are all and good, but at this level getting down and dirty and BUILDING something will teach you a lot more in my opinion.
Go and show your instructor the problem you are having, its his/her job to teach you and point you in the right direction.
He/she has to have more knowledge than some of us about Proteus.
