Topic: Stepper Motor Speed and Direction with one Potentiometer (Read 195 times) previous topic - next topic
ampedimagery
Looking for the best way to control speed and direction of a stepper motor using 1 pot
Robin2
Something like this ?
Code: [Select]
int potVal  = analogRead(potPin); // range 0-1023
potVal = potVal - 512; // range -512 to + 511
If (potVal < 0) {
  dirn = 'F';
else {
  dirn = 'R';
absPotVal = abs(potVal); // make sure it's positive
millisBetweenSteps = map(absPotVal, 0, 511, xx, mm) // xx = high value for slow speed, mm = low value for high speed
...R
Stepper Motor Basics
Simple Stepper Code
Two or three hours spent thinking and reading documentation solves most programming problems.
ampedimagery
I am very new to this and really dont know anything yet. This is my first arduino project. we are using a 12v nema 17 and eventually a 12v 12Nm Nema 34 to drive our machine. We are using 12v power supply, arduino, motor and l298n driver. i am wanting to change direction and speed in real time with a single pot
CrossRoads
potVal = potVal = 512; // range -512 to + 511
Typo perhaps?
Maybe this:
Robin2
Typo perhaps?
Thanks for spotting that. I have corrected it.
...R
Robin2
Have you carefully considered Reply #1 - does it meet your need?
...R
jremington
Quote
Start with something simpler, like getting your stepper to work.
You need an Arduino, an appropriate motor power supply, wire the driver to the motor without using a breadboard (because the breadboard connectors will burn) and importantly, set the motor driver current limit properly. You will need a multimeter for that.
