Topic: PC Steering wheel centering (Read 511 times) previous topic - next topic
swapnil_nimbalkar
Hello everyone,
I want to make a steering wheel for PC.  I want to make a centering mechanism for it.  Arduino will be used only to center the steering wheel.
Can someone help me with what components to use and code.
Here is what I am thinking of using
1) Disc encoder from old printer or rotary encoder
2) L298 Motor controller
3) Arudino Uno
4) 775 DC Motor
Thank you
Robin2
#1
Sep 17, 2020, 10:46 am Last Edit: Sep 17, 2020, 10:48 am by Robin2
In what circumstances do you want the Arduino to centre the wheel?
How do you define the centre position?
An L298 is almost certainly completely inadequate for a big 775 motor - what is the stall current for the motor.?
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
swapnil_nimbalkar
hi,
I am going to use an encoder to center the wheel.
I have tested the code with LED's.  It works as intended.  Will test it with L298 and motor soon.
Here is the code that I am planning to use.
Swapnil
swapnil_nimbalkar
Code: [Select]
[code]
 Steering wheel centering mechanism.
 This mechanism is independent of input that is going to the PC.  A mouse is mounted on a round shaft (shaft can rotate but mouse stays at its position), the input from mouse is used to control the steering of truck in the game (ETS2).
 An encoder is attached on one end of the shaft and the steering wheel is on the other end.  A DC motor connected through gears or pully is used to return the shaft to the center.  L298 controls the DC Motor.
 To be noted
 1) encoder has 38clicks for 360 degree rotation
 2) steering is designed to move 900 degrees, how to stop it beyond that
 #define inputCLK 4 //input pin CLK from encoder is attached to the digital pin 4 on uno
 #define inputDT 5 //input pin DT from encoder is attached to the digital pin 5 on uno
 #define in1 8 //output pin - when this pin is high motor rotates in CW direction
 #define in2 9 //output pin - when this pin is high motor rotates in CCW direction
 #define enA 3 //PWM signal to enable motor rotation
 int counter = 100; //this is center position of the encoder
 int currentStateCLK;
 int previousStateCLK;
 String encdir ="";
   // Set encoder pins as inputs
   pinMode (inputCLK,INPUT);
   pinMode (inputDT,INPUT);
   // Set motor pins as outputs
   pinMode (in1,OUTPUT);
   pinMode (in2,OUTPUT);
   pinMode (enA,OUTPUT);
   // Setup Serial Monitor
   Serial.begin (9600);
   // Read the initial state of inputCLK
   // Assign to previousStateCLK variable
   previousStateCLK = digitalRead(inputCLK);
  // Read the current state of inputCLK
   currentStateCLK = digitalRead(inputCLK);
   // If the previous and the current state of the inputCLK are different then a pulse has occured
   if (currentStateCLK != previousStateCLK){
     // If the inputDT state is different than the inputCLK state then
     // the encoder is rotating counterclockwise
     if (digitalRead(inputDT) != currentStateCLK)
       counter --;
       encdir ="CCW";
       // Encoder is rotating clockwise
       counter ++;
       encdir ="CW";
      previousStateCLK = currentStateCLK; //update previousStateCLK with the current state
       if (counter > 101) // if steering is moved, encoder should move too, thus we know motor need to start tuning to bring steering back to center
       digitalWrite(in1, HIGH);
       digitalWrite(in2, LOW);
       digitalWrite(enA, HIGH); // move motor although this is pwm pin I am not using PWM right now
       else if (counter < 99)
       digitalWrite(in1, LOW);
       digitalWrite(in2, HIGH);
       digitalWrite(enA, LOW); // stop motor
     Serial.print("Direction: ");
     Serial.print(encdir);
     Serial.print(" -- Value: ");
     Serial.println(counter);
[/code]
Robin2
I assume that means you don't need any further assistance because you have not answered my two questions.
...R
swapnil_nimbalkar
...R
No its not like that.  I think I was not able to put it in proper words to understand.
swapnil_nimbalkar
Here is an update,
I wanted to use a normal encoder (KY-40) for centering.  But it is not precise and sometimes jumps and won't center properly.
So, I changed my mind, I am going to use a PS2 mouse as an encoder, which is very precise.
The mouse will be mounted on steering shaft to record shaft position.  Accordingly Arduino will control DC motor to center the shaft.
I have tested the PS2 mouse with L298N and 12V DC Motor. It does move motor as intended.
I would like to add PID control to this system. Can someone help me with the PID loop?
Here's the code
Code: [Select]
#include "PS2Mouse.h"
#define enA 10 //PWM signal to enable motor rotation
int counter = 5000;
int motorSpeed = 0;
int counter1 = 0;
PS2Mouse mouse(6,5);
void loop(){
  uint8_t stat;
  int x,y;
  mouse.getPosition(stat,x,y);
  if (x>0)
    counter = counter + x;
  else if (x<0)
  if (counter > 5050) // if steering is moved, mouse should detect the movement, thus we know motor needs to start tuning to bring steering back to center
       digitalWrite(in1, HIGH);  // move motor in CW direction
       motorSpeed = map(counter, 5050, 8000, 0, 255);
       else if (counter < 4950)
       digitalWrite(in2, HIGH); // move motor in CCW direction
       counter1 = counter1 - 10000 ;
       counter1 = counter1 * -1;
       motorSpeed = map(counter1, 5050, 8000, 0, 255);
       motorSpeed = 0; // stop motor
       if (motorSpeed > 255) motorSpeed = 255;
       analogWrite (enA, motorSpeed);
Robin2
It's not a good idea to allow a long time between your Replies because we forget all about your problem. I suggest you check the Forum about twice per day to see if someone has responded in case you need to provide more information.
In Reply #2 you said "Here is the code that I am planning to use." That was nearly 2 weeks ago so I presume you have tested the program in the meantime, but you have no told us what happened when you tried it.
And you have still not answered my questions from Reply #1
...R
swapnil_nimbalkar
How do you define the center position?
...R
1) Center position is recorded when Arduino boots up (counter = 5000), now if I move my steering wheel this value will change depending upon which way I am going.
2) As you had pointed out that L298 wont suffice 775, so I am going to use some other geared motor which wont pull much current.  Since I dont wont force feedback other motor should fine too.
Stall current for 775 motor is about 14A.
...R
I really wanted to try and make my own code which took time.  Ofcourse I learned a lot during this process, that why I replied late.
...R
Yes I did test the program on work bench.  When I move mouse "counter" value changes and accordingly motor direction and PWM output changes too.
Now I want to add PID to this setup, can you help me with that?
Robin2
I'm still not clear about when you want the self-centering to happen (my first question). I'm beginning to think you want to create a system that creates a small force opposing the driver so that if he takes his hands off the wheel it will automatically return to the centre.
If that is what you want you may find that a small geared motor is not suitable because when the person turns the wheel s/he will be forcing the gears to turn the motor and they are not generally designed for that. A more powerful motor with a direct (or nearly direct) drive would be more suitable.
Quote
I'm not going to offer helo with that. I have done it for myself but it is not something I feel comfortable teaching. There is a nice simple PID function in this link
...R
swapnil_nimbalkar
As I said earlier, I am not be able to put whatever is in my mind into proper words for you to understand.
Thank you for the link.  I know about PID, but dont know how to implement it in programming language.
Your help is much appreciated.
Regards
Swapnil
Robin2
That's why I wrote (in Reply #9) my description of what I think is in your mind - did I get it right, or am I wrong?
...R
swapnil_nimbalkar
...R
You are absolutely correct.
