Recently, I started a project to change my car's tail lights into led strips. I'm using WS2812b as led strips and I've already managed to turn them on. Now the problem is, I can only switch them on when I'm using a push button on the breadboard.
Obviously, I can't keep pushing a button on the breadboard every time I use a signal light. So, I've decided to use LTV817 optocouplers per switch (left signal light, right signal light, brake light, tail light).
To my understanding, I can splice a wire from the 12v supply of the old halogen bulbs and connect the wires to the optocouplers then to arduino I/O input (schematic attached below). I've tested the circuit already but the leds won't turn on when switched from the optocouplers. It works just fine with push buttons.
Is there something wrong about the schematic?
