Arduino Forum
Using Arduino
Motors, Mechanics, Power and CNC
arduino mkr1000 wifi with a Solid State Relay?
Print
Pages:
[1]
Topic: arduino mkr1000 wifi with a Solid State Relay?
(Read 313 times)
previous topic
next topic
skaught
Newbie
[add]
Sep 19, 2020, 02:06 am
I would like to drive a single channel solid state relay capable of handling 120vac @<1amp as directly as possible from a mkr1000.
Small size matters greatly. Switching speed does not matter at all as the switching frequency will be less than 1 hz.
The relay will trigger as many as 3000 times per day and will need to operate for many years so it must be a SSR.
This application will pull a 120vac (low current) control signal to low for 1 second intervals based on the wifi and programmatic responses.
Can the mkr1000 WIFI drive any SSRs? Is there a better option that is the same size as the mkr1000?
There is a 5vcc available however size is very restricted.
Thank you
Paul_KD7HB
Shannon Member
[add]
Prior work was computer software and data communications for 34 years. Then owner/President of an electronic assembly service for 20 years. Amateur radio since 1955, approximately. Live in Central Oregon desert.
Re: arduino mkr1000 wifi with a Solid State Relay?
#1
Sep 19, 2020, 02:36 am
Can your mkr1000 light a LED? That is all it takes for a SSR.
Paul
skaught
Newbie
[add]
#2
Sep 19, 2020, 03:33 am
Last Edit
: Sep 19, 2020, 03:36 am by skaught
That depends on the LED does it not?
And I do not have one yet, I will not buy my prototype Arduino until I can figure out which components are the best suited.
And which SSR? I need one that is very small and can work with the mkr1000 (or similar).
Wawa
Brattain Member
[add]
#3
Sep 19, 2020, 04:15 am
Even a small Omron G3MB-202P SSR needs the same or a bit more current than a 3.3volt pin can provide.
Common
SSR boards
solve that with a
transistor between pin and SSR LED
Leo..
skaught
Newbie
[add]
#4
Sep 19, 2020, 06:15 am
I am having trouble finding any commonly.
ballscrewbob
Global Moderator
? < This is a question. Try to answer
Shannon Member
[add]
#5
Sep 19, 2020, 02:24 pm
Last Edit
: Sep 19, 2020, 02:30 pm by ballscrewbob
Random thought but would a
level shifter
be suitable for running an SSR ?
They can be had in very small module sizes maybe enough to glue to the side of an SSR.
Many of the Chinese modules also claim to run from 3 volts too.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
CrossRoads
Global Moderator
Unlimited Eagle board sizes available.
Brattain Member
[add]
Author of "Arduino for Teens". Available for Design & Build services. Now with Unlimited Eagle board sizes!
http://www.crossroadsfencing.com/BobuinoRev17/
#6
Sep 19, 2020, 11:50 pm
How about this SSR instead, if you can live with just 825mA of switching current:
https://www.infineon.com/dgdl/pvt212.pdf?fileId=5546d462533600a4015356841646295d
Can the MKR1000 drive 5mA?
Datasheet for the chip would suggest that at least some of the IOs can sink up to 10mA.
Designing & building electrical circuits for over 25 years. Screw Shield for Mega/Due/Uno, Bobuino with ATMega1284P, & other '328P & '1284P creations & offerings at my website.
skaught
Newbie
[add]
#7
Sep 20, 2020, 04:28 am
@CrossRoads This looks perfect!! THANK YOU!
skaught
Newbie
[add]
#8
Sep 20, 2020, 04:38 am
@ballscrewbob
That is also a great idea, I'll try that too!
Thanks!
Print
Pages:
[1]
Loading...
